Review of / Measurement on Xtar WP2
HKJ
Copenhagen, Denmark
[size=+3]Charger Xtar WP2[/size]
This charger was introduced in 2010 and announced as a CC/CV charger. It has two channels, i.e. it can do two cells independently of each other.
It comes in a cardboard box with a view to the charger and specifications on the back.
The charger is powered from a single 12 volt DC connector, this connector can be powered from either the supplied AC adapter or from a car adapter. The AC adapter I got is a universal voltage adapter (100 - 240 VAC 50/60 Hz) with a plug for European use.
There is a led for each channel, this led will be red when the charger is charging and green at all other times.
The charger can handle 70 mm long batteries, with flat top cells it is necessary to place them carefully to get a connection.
[size=+2]Measurements[/size]
Below 1.5 volt the charger does not charge, it discharges with 20-30 uA.
Between 1.5 and 2.8 volt the charger charges with about 80 mA.
Between 2.8 and 4.18 volt the charger is applying regular charge current (See curve below).
When the charge current goes below 200mA the charging is stopped and it will discharges with < 100 uA.
The charger will restart charging when the cell drops to 4.06 volt.
When charger is disconnected from power, but with a battery in, it will draw about 230 uA from the battery.
Two batteries will only change the current a little bit (about 5%).
Because each channel is independent, the different voltages varies between the channels with a small amount.
The charge curve shows a good approximation to a CC/CV charger, but the charger stops to early.
Same battery on the other channel, some small differences in terminating current and voltage can be seen.
My old 16340 IMR cell. Here is a problem with the difference between turn off point and turn on again, the battery drops enough in voltage to start the charger again. If the charger had terminated at a lower current, this restarting would have been a much smaller problem.
A closer look on all the noise in the current shows that the charger stops charging each time it want to measure voltage. This has the advantage that all connection resistance can be ignored and noise from the charger is eliminated.
The first curve did not show much noise in the charge current, but that was because I used a filter. Without a filter it can be seen that it contains a lot of noise.
In this chart I have zoomed in on the noise.
[size=+2]Conclusion[/size]
The charger is very close to a CC/CV charging profile and the trick about stopping charging to measure the voltage makes it possible to control the charge very precisely, but the chargers does not take advantage of this. Because it stops charging to early and does also start recharging at a high voltage, it is not a perfect charger. No charging at low voltages might also give problems activating a tripped protection.
[size=+3]Notes[/size]
Here is an explanation on how I did the above charge curves: How do I test a charger
cocoro1967
japan saitama
Hello, HKJ
I am always enjoying your Review.:clap::clap:
Thank you very splendid Review.
Look at this, I also bought.
selfbuilt
Wow, nice review HKJ. :thumbsup:
A very thorough investigation of the charging method. I like your higher resolution time scans. It does indeed looks like the charger is purposefully pausing the charge to check the voltage. A pity it doesn't do a better job with proper termination.
HKJ
Copenhagen, Denmark
Thanks, I am working on a couple of charger reviews in this style, I have already posted WP6, 4Sevens (Where I found a fault in the charger) and WF-139.
http://www.candlepowerforums.com/vb/showthread.php?309456-Review-of-Measurements-on-WF-139
The termination is way to high, it might also be the reason you can start charging again in your review. The test run with the old IMR cell shows the problem very clearly.
When using the charger for 18650 batteries the capacity loss due to the early termination is not really a large problem, but when using it for cells with lower capacity it is significant.
selfbuilt
Good to know. Given how dependent we are on these sorts of chargers for all our rechargeable cells, it is good have detailed investigations of them! :candle:
Yeah, that would make sense. Agreed that this is much more of a problem for lower capacity cells (i.e. RCR). I'll be sticking with my Pila for regular every day use.
Milestar
XTAR is going to release the New Updated WP2, I still like to offer this new product's reviewing opportunity to HKJ and Selfbuilt once it is announced released since your guys job is excellent splendid, can I have the honor?
Miles
HKJ
Copenhagen, Denmark
Miles
I would very much like to review it, you can use a PM or email (See my website) to agree on the details.
Milestar
Thank you for your kind supporting!
I will email you to ageer on the details before I send the charger out.
Miles
