Review of the RQ
randomlugia
Packaging/First Impressions
The shipping on this one was terrible. From the time I ordered it, to the day it arrived, was 17 days. It didn't even ship for the first 6 days, and for some reason stopped for another 2 while it was still in HK. The packaging was good though; in the standard yellow bubble envelope wrapped VERY tighly in more bubble wrap (there was so much it took me almost a minute to get it out). So I don't think there will be any problems with the packaging.
This light is apparently an exact clone (on the outside) of the Raidfire Spear, which is no longer made. I have read comments from several other people that own both lights, that confirm they were most likely made in the same same factory after the Spear was discontinued. The only differences being the reflector, driver, and switch.
It feels sturdy; more than what you'd expect from a $30 budget light. There were no marks or defects in the coating or reflector when it arrived. The printing is sharp, but I think it might be a little crooked. If it is, it's extremely hard to see, and that's the only complaint I could think of after studying it for a while. The lanyard also looks cheap, but so far no problems.
Design/Feel
The design is really unique, and I like it a lot, though I'm not sure if the reflector actually works as a heatsink. Not that it needs it; the light barely gets warm after being on for long periods of time. The knurling is extremely fine, and totally useless IMO. I think it's just for looks, but there are plenty of other grooves in the design to help you hold it. Anti-roll is good, becuase of the tailcap shape it won't roll at all. Plus it can tailstand!
Preformance
Beam is ringy... probably the ringy-est beam I've ever seen in an LED light. This isn't really a problem as I only pay attention the the throw outside, and you can barely see it. It has decent flood, but this is nowhere near being a floodlight. I would actually prefer less spill and more throw, but it's a pretty good balence for a throw light and the beam still goes plenty far. The beam is also pretty cool, so if you're a tint freak it might bother you. In my opinion tint is useless in a throw light, because the only purpose of it is to light up a target brightly at a distance, not make it look nice.
From left to right: RQ, Aurora Ak-P7-5, Spiderfire P7
Aurora AK-P7-5 (2-mode):
Spiderfire P7:
Kai RQ:
Spiderfire P7:
Kai RQ:
The UI is strange, but still simple. The light will come on in the mode it was turned off in, but only if it was in that mode for at least two seconds. So for example, if it's in high, and you want it to come on low next time, you would blink it once and then click all the way. If you wanted it on high next time, you would just turn it off.
Conclusion
Pros:
-Can Tailstand
-I like the UI better than the standard "high->low->off"
-Love the design!
-Feels good in my hand
-Stays cool
-Good runtime, and far-throwing beam
Cons:
-Ringy beam
-Threads are a little rough on the tailcap, though not bad
It's an amazing value for your money, and I'm pretty sure this is the best quality you're going to get in a thrower for less than $60. Definately recommended, but only as a thrower because this light is hard to use up close.
Re: Review of the Kaidomain RQ
Good review.:thumbsup:
I have the MC-E version. good light
I don't have a Uniquefire, but I've heard that those two had a beam so narrow they're difficult to use. I'd also like to see that comparison... These are the only three nice lights I have at the moment.
You got me a little worried with your review...I just ordered an RQ today based on everyones raves about it and frankly, I think that the Aurora AK P7-5 kicked its royal a#@!!
What's the drop-in on the Aurora? Looks like it might be an XP-G-R5 or an SST50.
Thanks for the review.
The RQ was completely designed for throw. Of course it doesn't have as much total light (Aurora is around 450 lumens), but it throws way further. Just look at the last beamshot, you can't even see the red trashcan using the P7-5. In most situations, a P7 or other high power floodlight is preferred, but if you need to spot something 100 yards away, a P7 is next to useless.
The Aurora uses an SSC P7 emitter, and it's not a drop-in - the pill screws in.
All I can say is that I love my RQ.
It throws really far and based on my runtime test it can last 4 3hrs on a quality 18650 battery on high.
Runtime test done:
1. High Mode: Trustfire 900mah 14500 (used a spacer to fit in RQ)
1hr before it start to flicker
2. Low Mode: Ultrafire 18650 Battery gray
24hr+ (turned it off when noticed a slight change in output).
Definitely a great buy.:thumbsup:
Rather sad that the original RaidFire Spear is no longer available. :(
