Review of ThruNite TiKey, a small keychain light.
HKJ
Copenhagen, Denmark
[SIZE=+3]ThruNite TiKey[/SIZE]
This is the first flashlight from a "new" company, it is a small light keychain light in titanium with a 5 mm led.
The light is delivered in a cardboard box with and has a foam inlay with cutouts for the light and an extra set of batteries (There is also batteries in the light). A split ring is supplied. It was a bit difficult to get the light and batteries out, until I found out that I could take the foam out and press from the back. The spelling on the box is a bit creative.
Comparing it to AA and AAA cells it can be seen that it is a small light.
A look at the frontend shows the 5 mm led and the "reflector" (a 5 mm led does not really need a reflector, because most light is already focussed out the front).
Turning the light around and looking at the tail, where the hole for mounting the split ring can be seen. Because the end of the pin is rounded it prevents the light from tailstanding. I would have prefered a more solid split ring, than the supplied one.
Opening the light, it is easy to pull out the isolation tube and the spring (This light is no battery crusher). Also note the bump on the pcb, this is a very nice way to make battery contact.
For modders: The battery tube fits a 10180 battery, but it does not make connection. I did not investigate further, because I am not sure that the led can take the voltage, it might be necessary to add a resistor.
[SIZE=+2]Technical specification and measurements[/SIZE]
The light uses 3xLR44 batteries with direct drive to a Nichia GS led.
The light is specified for a maximum output of 10 lumen, but this output will drop fast to a much lower level. Letting the light rest will recover some of the brightness again, on the curve below I let the light run for 5 minutes and rest for 15 minutes:
When just turned on the current draw is about 40mA.
I have measured the size to: Total length: 46.3 mm, 5.4 mm is the pin at the rear. Diameter is 16.6 mm, pin is 8.1 mm.
The weight is 29 grams including batteries.
The GS led has a purple beam as can be seen on this beamshot:
[SIZE=+2]Comparison to other Flashlights[/SIZE]
There are no light exactly like the TiKey on the market, usual titanium lights are much more expensive. I have selected the following light for comparison:
  • La Petite Killer, a custom titanium light with a 5 mm led, uses one SR44 battery (This light is more than twice the price of TiKey).
  • Peak Eiger #2 warm in stainless steel, running on a LiIon 10180 battery.
  • Fenix E01, a aluminum light using ordinary AAA batteries.
All of them has drivers, only the TiKey is direct drive.
Measuring the brightness (With a ceiling bounce) is just as expected, lights with more battery power are brighter. Remember that the TiKey is direct drive and the output will go down, if kept on for an extended time.
[SIZE=+1]La Petite Killer[/SIZE]
[SIZE=+1]ThruNite TiKey[/SIZE]
[SIZE=+1]Peak Eiger #2 warm[/SIZE]
[SIZE=+1]Fenix E01[/SIZE]
[SIZE=+2]Conclusion[/SIZE]
The light is a nice light with good machining and a good deal for the current price, but it has some limitations. With the direct drive and small batteries it is not designed to be on for a long time, but more for short bursts of light. This usage pattern fits perfectly with most keychain use.
I believe that ThruNite with this light has shown a good start and am looking forward to the next light from them, I hope they either add a driver or changes to LiIon batteries, and continue making nicely machined titanium lights.
That is really one nice review on a light that I intend to purchase as I like smaller lights!!
Good news is you can pick one up from an Austrian dealer for a fraction of the normal selling price.;)
