Review: Streamlight Waypoint Rechargeable (built-in battery)
subwoofer
Hove, UK
A few years ago I reviewed an earlier incarnation of the Waypoint, but with this updated version, output is boosted by four times and it is now powered by a built in rechargeable li-ion battery. The ergonomic pistol-grip design certainly lives up to its name.
Taking a more detailed look:
The Waypoint arrives in a cardboard box.
Flipping the lid open, this is how the contents are presented.
In the box you get the Waypoint with wrist strap , a wall mount, mains charger with selection of plug adapters and the instructions.
The plastic wall holder has three screw holes for mounting to a suitable surface.
With an open bottom, the wall holder can be positioned such that if the Waypoint is turned on it will shine wherever you directed it. You can also see the Velcro like retaining strap to keep the Waypoint firmly in place. If you mounted it in a vehicle, this would stop it coming out of the holder on bumpy roads.
On the back of the Waypoint is a mode selection lever with three positions for High, Medium and Low indicated with a full circle, half circle and quarter circle symbols.
The main switch is a 'trigger' style forward clicky in keeping with the pistol grip.
Looking from behind, notice the cushioned rubber grip, covered charging port, charge indicator light, mode switch and folded hanging loop.
And here with the hanging loop open and the charging port cover removed.
The charging port cover locks into place to stop it falling out.
To remove the port cover, twist it 90 degrees to unlock.
Then pull the cover off to give access to the DC socket.
As well as the hanging loop, the Waypoint has a built in stand fitted to the top.
This flips open with click stops to allow you to leave it at any angle.
Once placed onto the stand, you can aim the waypoint and use it hands free.
A large reflector is surrounded by rubber armour.
Though specified by Streamlight as a C4 LED it is an XM-L2 LED.
The beam
Starting indoors, as per its name, the Waypoint has a very focussed beam and shows a very strong hotspot, but still a reasonably useful spill.
Going outdoors to allow the Waypoint to flex its muscles more it very throw biased beam has washed out the centre of the photograph.
To really show the Waypoint at its best you need more distance, and here I've moved to a golf range. (The Waypoint itself is lit up as I'm wearing a headlamp set to a low level intended to show the model I'm testing)
Looking at the hotspot area a bit closer you can see the four distance markers at 100, 150, 200 and 250 yards.
You definitely can 'point the way' with the Waypoint!
Modes and User Interface:
The Waypoint gives you a very simple and intuitive interface. On the back of the Waypoint is a mode selection lever with three positions for High, Medium and Low indicated with a full circle, half circle and quarter circle symbols. The desired output mode is simply pre-selected, or changed during use.
The main switch is a 'trigger' style forward clicky in keeping with the pistol grip. The switch allows momentary use or constant on use.
Batteries and output:
The runs on a built in unspecified li-ion battery pack.
On the supplied charger, Streamlight have helpfully labelled what it is for (I wish more manufacturers did).
During charging the indicator light is red.
Once fully charged the indicator turns green.
___________________________________________________________________________________________________________
Streamlight WAYPOINT RechargeableI.S. measured ANSI output LumensPWM frequency or Strobe frequency (Hz)
High10960
Medium560100
Low36156
Peak Beam intensity measured 132000lx @1m giving a beam range of 727m.
It is not possible to confirm if there is any parasitic drain.
Output is not regulated and declines steadily over the entire runtime. Though a lower overall performance than a regulated output light, the Waypoint will not suddenly cut out leaving you in the dark.
Troubleshooting
This section is included to mention any minor niggles I come across during testing, in case the information helps anyone else.
The Waypoint Rechargeable in use
The first thing I'd like to mention is how I would classify this light. With so many different usage scenarios for which we have a wide range of choices, I'd put the Waypoint into the 'Static Equipment' class.
What I mean by this is that I'd see it as part of the standard equipment of a lookout point, search and rescue vehicle, on a boat, or any other instance where you are not personally carrying your equipment. Instead you have a kit of various items organised and mounted for quick access.
I would never EDC the Waypoint, with its fixed battery and bulky form it does not lend itself to a walk in the woods or camping.
Having put it in its place, when you are reaching for a light to scan the landscape and point out areas of interest, the Waypoint is ideal. Its pistol grip lends itself to pointing the beam naturally as you are looking around.
There is a soft start and stop of the beam as you use the trigger to switch it on and off. This prevents you from rapidly flashing the output. You can still signal with it, but not as fast as with other lights. The trigger switch itself feels a bit spongy and needs a long pull to reach the click that latches the output. This is not a problem, merely an observation.
On the two lower output levels, the PWM frequency gets my PWM sensitivity squirming. The PWM used is low at 100Hz and 156Hz and is obvious with any movement. Thankfully you will generally only want to use maximum output.
My own preference is for the Yellow version on test, the Waypoint comes in a black version as well, but when I'm grabbing a light I don't want it hiding in low light. It has another advantage that its pistol shape will never be mistaken for anything but the tool that it is.
When I can justify having it to hand, the Waypoint rechargeable is a pleasure to use. For road vehicles and boats (combined with a 12V adapter) it is an ideal choice and worth considering when kitting yourself out.
Review Summary
Things I likeWhat doesn't work so well for me
Intuitive, ergonomic designRelatively bulky
Powerful throw with 727m beam rangeBuilt in battery limiting extended use
Rechargeable – so nothing extra neededOutput is not regulated
Rubber armouredVisible PWM on Medium and Low
Built-in adjustable stand
Comfortable wrist strap
Wall mount
Thanks, again, for another fine review. I really appreciate the effort you put into it.
Is it fair to say that the beam intensity will fall in proportion to light output? For the better part of a run, it looks like output is around 500 lumens. As that is half of the nominal 1000 lumens you get on a fully charged battery, does that mean beam distance is cut in half as your battery drains, or is it candela that gets cut in half?
Sorry to say, I cannot remember which it is.
Since beam intensity is measured in candelas, when the beam dims the candelas will drop along with it. A point to keep in mind since it is an unregulated light.
One other point: Unless I am mistaken, the rechargeable Waypoint can not be used while it is recharging. There is a companion Waypoint that uses four C cells for portable use, or plugs into a 12v source and becomes a free-standing fixed location light (that 'fixed location' can be a moving vehicle, but it is fixed in that it can move no further than the length of the supplied cord).
In short, yes. With the only change being the OTF lumens, the lux @1m and resultant beam range should drop proportionally.
Absolutely right, there is an 'Akaline' Waypoint, but its output is half that of the rechargeable Waypoint. If only Streamlight had made the Rechargeable version able to run directly off a 12V source like the alkaline version it would have added greatly as it would then be able to maintain full output and beam range.
Are you sure about this being proportional? Wouldn't it be more like 70.7% (square root of .5) throw for 50% brightness/cd?? Just trying to understand.
Any way thanks for another great review!
Without measuring it (which is a bit tricky as actual OTF lumens vary over time as this is not a regulated light), I'm not 100% sure, but remember I said the lux @1m would drop proportionally, NOT the beam range.
My reasoning is that if I measure 132000lx @1m 30s from turn-on for a freshly charged Waypoint, and in the same condition (freshly charged, 30s from turn-on) I measure 1096lm OTF, this gives us a good indication that a 1096lm OTF output with this reflector/lens/LED will give 132000lx @1m.
The crucial bit there is "with this reflector/lens/LED", as if the OTF lumens drop to 548lm (half) and the only change is the OTF lumens, then I expect the Lux @1m to halve to 66000lx @1m.
As I mentioned previously I was talking lux@1m and beam range is calculated as SQRT(Lux@1m)x2 so the drop from 1096lm OTF to 548lm OTF (and proportional drop in lux@1m) would result in a beam range dropping from 727m to 514m (not half).
OK that makes sense, I thought that you were saying both cd and beam distance were proportional to lumens.
Thanks for the reply.
