[Review] - XTAR VC4S Charger QC3.0 3000mA - by Lock
lock
XTAR VC4S: the multi-chemical charger for Li-Ion / Ni-Mh batteries equipped with an LCD screen and powered by a QC3.0 port that can supply a current of 3.0A on each single slot.
Main features
• LCD display showing all current cell information and charge status
• Widely compatible with all cylindrical lithium and Ni-Mh batteries
• Quick charge QC3.0, Max 3A for each slot
• Cell capacity test
• Micro-USB input
• Automatic battery type detection
• Guaranteed safety thanks to protections against overcharging, overheating and polarity reversal
• High precision, auto-off when charging is complete
• Input: QC3.0 (5V-3A or 9V-2A)
• Constant current: 3Ax1 / 2Ax2 / 1Ax4 / 0.5Ax4
• Automatic interruption of the charge (Voltage): 4.2 ± 0.05V / 1.45 ± 0.1V
• Automatic charge interruption (Current): less than 120mA
• Operating temperature: 0-40 ° C
• Dimensions: 149 mm x 115 mm x 35 mm
• Weight: 212 grams
• Compatible with the following 3.6 V / 3.7 V Li-Ion / IMR / INR / ICR battery models 10440 14500 14650 16340 17335 17500 17670 18350 18490 18500 18650 18700 20700 21700 22650 25500 26650 32650 and with Ni- batteries MH / Ni-CD: AAAA / AAA / AA / A / SC / C / D. Note: 20700/21700 protected batteries cannot be charged
Product description
The XTAR VC4S comes in a white cardboard box with all the main product information printed on it. Inside the package you will find the charger inside a nice carrying bag together with the QC3.0 cable and the user manual.
The body is made entirely of high quality flame retardant and self-extinguishing ABS.
The VC4S is equipped with a large color display where all the cell information and their charging status can be displayed. The viewing angle is 170 °.
There are two switches "Disp" and "Mode" which are used respectively to change the display of information (Capacity, Current and Internal Resistance) and to change the charge settings (Charge, Grading and Storing Mode).
The slots for the cells has enough sliding slides. The insertion takes place without any difficulty and in a very fluid manner. It is possible to load cells up to 70mm long so it is for example 21700 and 20700 (but unprotected) batteries. The two side slots can accommodate two 32650 cells simultaneously, while only 3x26650 can be loaded simultaneously
Laterally and on the back there are dissipation fins that allow a good dispersion of the heat produced during the charging phase. The VC4S also has a temperature control system inside to prevent overheating.
At the front there is the QC3.0 interface, for maximum compatibility with commonly used power supplies.
At the rear are all the power supply and compatibility features of the accepted batteries.
Functions of the XTAR VC4S
The operations and functions of the XTAR VC4S are varied and, thanks to the presence of a large LCD display, it is always possible to have, for each recharge channel, information such as the state of charge, the accumulated capacity and the health status of the cells ( Internal Resistance).
To charge a cell, just insert it inside the charger and you're done! The current will be chosen automatically by the charger based on the health status of the cell and the availability of current supplied by the charger.
We have three modes of operation:
Charge Mode : Once the cell is inserted, the VC4S recognizes the type of chemistry and automatically chooses the ideal charging current.
Grade Mode : During this phase the charger tests the real capacity of the cell through a "charge-discharge-recharge" process
Storage Mode : In this mode the battery is brought to its nominal voltage 1.2V / 3.7V. This voltage is ideal for storage should the cell not be used for a long time.
LCD Display
The LCD display shows, in a tachymeter style, the instantaneous voltage of the batteries (in the white part) on a scale from 0V to 4.2V, the charging current (in the blue part) on a scale ranging from 0.5A to 3.0A. furthermore there is a counter for the accumulated current capacity and the indication on the type of chemistry of the cell being charged.
In charging mode, by pressing the "Disp" switch, it is possible to view for each slot the accumulated capacity from the beginning of the charging phase (CAP), the charging current (CUR) the internal resistance (IR).
If instead Mode is pressed, the operating modes will charge (Charge, Store and Grading)
Below the display, for each slot, there are red or green backlit messages. The meaning of the colors is as follows:
• Green: stand-by / charge complete / Grading or Storing mode completed.
• Red: test / charge / activation.
Battery Activation Function
The VC4S is able to activate lithium ion batteries with a protection circuit. After installing the battery, the charger will test and activate the battery before starting to charge it.
Turning off brightness
After 1 minute without any activity the screen will automatically go into standby turning off .. Just press any button to reactivate.
Final considerations
The XTAR VC4S is a quality charger, complete and simple to use.
The display is truly exceptional and perfectly visible from any angle, it is also quite wide and allows you to view all the information on the charging and on the status of the cells. I like the fact that it is able to see the internal resistance of the battery (information that allows us to understand when it is time to "retire" that cell).
The VC4S is also a safe product thanks to the presence of a series of control mechanisms: we have protections against polarity inversion, against short circuits, against overheating.
It can be powered from a convenient QC3.0 port (5V 3.0A max) via the supplied cable.
The two Grading functions are very convenient for testing and understanding how much current a cell is able to accumulate during the charge and Storaging phase that allows to bring the cell voltage to its nominal value (utiule for storage for long periods).
This XTAR VC4S is a satisfactory product, it is simple to use, it works well, it has all the functions that a charger needs to have.
Thanks for reading!!
hammerjoe
With minimum charge being 500mah I dont think I would buy this to charge nimh batteries.
Does it adapt the charging current based on the IR of the battery as well?
daffy
Im currently investigating if i can get a charger that will do protected 21700 as well as 18650/16340, having 1 charger do all would be more convenient.
Mishanchik
Russia
The author of the review received a charger, did a review, but it is not interesting to discuss - the device has already been received :)
