Review XTAR VC8
Tomaao
XTAR is a manufacturer who focus on the battery chargers. Its products have always been aimed at high performance and reliability. I bought a VC8 charger, which can charge 8 pieces of 21700 batteries at the same time.
Appearance
The charging battery quantity determines the charger’s volume. The XTAR VC8 has 8 bays, so its overall size reaches 194mm x 134mm x 34mm, and the net weight is close to 350g, which is a large size in the chargers.
Wide Compatibility
Although VC8 has a large size, it supports 6 pieces of 26650 batteries or 8 pieces of 21700 batteries.
In daily use, all the common lithium batteries can be installed, from 16340 to 26650. If you have many flashlights or need to use many batteries, this VC8 charger will bring you convenience.
Two LCD Screens
VC8 has two LCD screens, which looks like two 4-bay chargers side by side.
XTAR's LOGO and the “VC8” model are placed in the middle of the two screens, which is very eye-catching.
The screen has a protective film. You can remove it when used.
Chute Design
The charger uses a chute design, which is also the structure used by most chargers. This structure is stable, reliable and easy to use.
The contact plate of the chute adopts nickel plating process, so there is no need to worry about the durability.
Grading And Storage Mode
The channels of VC8 are marked CH1 to CH8 from left to right. And the CH1 to CH4 not only can be used for charging, but also support battery capacity test and charging in storage mode.
Storage Mode
Generally, if the lithium batteries are not used for a long time, the battery capacity should not be too full or too low. The ideal voltage is 3.6-3.8V, because it can prevent the battery from passivation to maintain performance.
The storage mode of VC8 is to charge the battery to 3.7V which is suitable for long-term storage. If the battery voltage is higher than 3.7v, the VC8 will perform the discharge operation, and if it is lower than 3.7v, the charging operation will be performed for long-term storage.
Charging FeLiO4P Batteries
The storage mode also has a major role, that is charging the FeLiO4P battery. You know that the voltage of the FeLiO4P battery is 3V, and it is about 3.6V after being fully charged. It can also charge up to 4.2v, but it is not far from death (I have done it many times). That means, the terminal voltage of the storage mode is almost the same as that of the FeLiO4P battery. Therefore, another function of this mode is to directly charge the FeLiO4P battery.
Grading Mode
The capacity test of VC8 is to fully charge the battery, then discharge it, and then recharge it for a cycle. The VC8 calculates the battery capacity through the discharge current and time.
It should be noted that because the silent design of VC8, it doesn’t have a fan, so the current will not be too large during discharge, only about 300mA. Therefore this test takes a long time.
0V Activation Function
After playing with the flashlight for many years, I found that it is normal for batteries to be over-discharged in daily use. The flashlight is often forgotten to be turned off or turned on by mistake.
Generally, the charger will rely on detecting the battery voltage to determine which type of battery it is. It is a 1.2V AA NiMH battery or a 3.7V Li-ion. The battery is judged by the initial voltage. If you put a battery with no voltage, some chargers will not charge at all.
A protected battery generally disconnects when it reaches the cut-off voltage. There is no voltage at the two ends of the battery (test with a multimeter). So a charging voltage is required to "activate" the protection board before the charger can detect the battery type.
After testing, the VC8 channels have an activation voltage when they are not loaded, so whether the battery has protected board or not, it can automatically start activated charging.
This activation process is probably to slowly charge to a certain voltage first, then start the set power for fast charging, and finally use constant voltage charging to supplement.
Performance Test
The VC8 has a charging protection function. It will prompt ERR and stop charging for the battery that cannot be activated, installed incorrectly or non-rechargeable.
The input of the VC8 charger adopts the mainstream USB-C port, and supports QC 3.0 fast charger. I measured that the VC8 will automatically apply for 9V voltage, the maximum current is about 2A, which is about 18W input power.
Battery Grading Test
The following is a set of charge and discharge tests. The batteries tested are three XTAR rechargeable batteries, which are 18600 2600mAh, 20700 3000mAh, and 21700 4200mAh.
XTAR 18650 2600mAh, real capacity is 2460mAh.
XTAR 20700 3000mAh, real capacity is 2895mAh.
XTAR 21700 4200mAh, real capacity is 4025mAh.
Compared with the professional volume measuring equipment before, the accuracy error of the two is within 5%.
In terms of the capacity, there is still a slight gap compared with the top series of lithium battery, but the capacity of XTAR batteries have no falsification.
Charging 6 batteries with 16W power
Finally, I made a set of charging tests. First test the charging of 6 batteries - two 21700, two 20700 and two 18650. The total time is about 7 hours and 20 minutes, a total power consumption of 89 watt hours.
Since VC8 supports QC 3.0 fast charging, the charger automatically applies for 9V voltage as soon as it is connected to the power supply, and the maximum charging current reaches 1.8A. The first 5 hours were basically charged at 16W full power.
Charging 2 Batteries With 22W Power
Then a group of 2 x 18650 charging tests were done. The whole process took only 1 hour and 20 minutes, but the measured charging power was actually greater. Almost the entire current was above 2A, and the maximum power exceeded 2.2A, which is close to 20W input power. It's amazing.
Storage Mode Test
Finally, I did a set of tests on the storage mode. Two 20700 batteries in the storage mode was charged. The result is interesting. It seems that the storage mode limits the charging current, which is only about 9V 0.5A, i.e. 4.5W. It took me 4 hours in total.
Temperature Control
During the test, the heating of VC8 was well controlled during charging, and the temperature was not particularly high.
When the battery is discharged, the temperature in some areas on the back reaches 49℃, which is still a good result for passive air-cooled chargers, because generally the temperature of active air-cooled chargers is high when performing discharge tests. Not to mention passive heat dissipation.
Internal
Structure of VC8
The last part is the disassembly part. Due to the huge size, the charger uses up to 9 screws to fix it. Remove the screws to clearly see the internal structure. The overall wiring is very neat, the original patch welding is accurate, and the wiring is not found with any hidden dangers.
It can be clearly seen from the circuit configuration that the circuit of slot 1-4 has significantly more components than the circuit of slot 5-8. After all, the slot 1-4 has discharge part, so there are some differences. The USB-C port adopts independent interface board design, easy to replace if damaged.
A simple test of the material of the chute basically concluded that it is not made of copper, but the metal sheet of the chute is very thick, which has less effect to the internal resistance.
The inductance part is on the back of the circuit, and the wiring is very neat. The screen control is an independent four screen display chips, which are placed on the back of the screen.
Conclusion
Pros
- VC8 is suitable for users with many batteries. The 8 bays make you no need of waiting.
- VC8 can test battery capacity and detect internal resistance. When using multiple batteries, the battery performance can be better matched to maximize the use time.
- USB-C charging.
Cons
- charging current. 3A is only for single slot.
- 2x3A, 4x2A and 8x1A may be the ideal current.
I have to say that high-power charging still has an effect on the capacity. It is indeed not as good as the low-power charging in full charge.
MAD777
White Mountains, NH, USA
Great review! Can the charging amps be controlled by the user, or it's always 3A when charging a single cell?
Secondly, how is the VC8 when charging smaller cells, like 16340's, etc.?
Sent from my Pixel 2 using Tapatalk
Tomaao
Thank you;)
The charging amps can't be manual selected. It's automatically. The charging current depends on the input power supply and battery status.
I used a QC3.0 adapter to connect VC8, it reached 3A for single cell, but when I charged VC8 on my laptop, it didn't reach that value, because the power was only 5V 2A.
I think the VC8 is good at charging li ion battery, including the small cells, but it is not so good when it charge AA/AAA batteries.
Eneloops
Thank you;)
That's simply just not true. This is straight from the manual:
"Press "Curr" button to switch charging current, 3A/2A/1A/0.5A/0.25A."
