LGCubana
I'm only using fresh Duracell alkalines in my Rex 2.0
So I don't know if my results are tainted by not using a higher voltage.
I see no flicker on Low-Med-High; in an absolutely black room.
I've run the beam across a white wall. No distintive 0 0 0 0 0 0
also
My User interface is different to the product description. I've tried having the light on High for:
5
10
15
25
30 seconds, then turning it off for 10 or 30 seconds. Always turns back on in the next mode, strobe.
Does anyone else have the same UI ?
[Edit to Add]
Disregard my malfunctioning/unique UI. Just had the opportunity to use an AW, 3.7v, 14500.
Still no flicker & the UI's 5 second memory rention is working
also
5
10
15
25
[Edit to Add]
