Riverrock/Aurora/Stormlite 2AA anyone modded this ?
mpc
I have a Stormlite Aurora 2AA Nichia Jupiter. It has an optic, which produces a tight circle of blue light with several rings spreading out. It's more a an oddity than of any real use.
Has anyone opened this and tried to insert a Cree (with or without star). I would love to make this a useful light
In fact any info on modding this would be useful - especially how to open the head. I thought about using heat, but the lens is plastic.
Thanks !
Okay, I got the head off - very hard to do. Minor blemish on the knurling/namestamp.
Now to order a cree :)
I put an Cree X-RE P4 WC in mine (starmounted). I set the focus so it projects the leds die shape in perfect detail. If you want a more floody beam you have to increase the focal height with a spacer or similar between the headassembly and the led pill. In order for the star to fit you either have to trim the stars outer edges or remove the black plastic reflector shaped thingy. With an Cree it's a throw monster. Mine throws as far as my D-Mini, not as bright as the D-Mini obviously. It's almost only throw, but it throws far. Output (throw) increases from about 450 lux to 4700 lux with alkaline cells. MAJOR improvement in flux, ~10 times the flux compared to the stock emitter.
Stefan
Thanks for the reply Stefan. I was hoping it would be a throw monster :)
Since I already have a Cree light on order I thought it would be nice to have a change
I have ordered an SSC U-bin from Dealextreme. I believe that the star is electrically isolated so I should be able to use that. I know the SSC has a difference in emission angle - and I will have to be careful with that "Gummy" dome.
I intend to post photos of the emitter swap, and possibly some beam shots.
Did you do anything with the Nichia Jupiter LED ? I may put it into the last remaining ARC AAA clones that I have.
Heating didn't work. This is what I did.
Wrapped two pieces of very tough card around the head and body. The card MUST be very tough. This type was a piece of shiny junk mail. I used about 3 doubled over layers.
Molegrips - I unscrewed them until they slipped over the card. Then I screwed the adjustment screw tighter. I set it until I could just about close the molegrips - lots of strength required. (This would probably crush a similar aluminium light)
For the body section, make sure that the flat section of the body (where the logo is) makes contact with the flat section of the mole grip jaws.
Then apply a slow but very firm twisting motion - don't try to rush it, or you will cause damage to the body.
DonX_Fi said:
Hello
How did U opened the head ?
I wanna open head, too.
I managed to get mine apart one day when I was feeling real rowdy! I wrapped a rag around the head and one around the body and used large pliers to get mine apart, it came apart really hard. I am guessing if you had some strap wrenches they might be easier on the metal, I managed to mangle the knurling a bit.
It's cool to find this thread, I was just looking at the light the other day and deciding how to pop a cree into it!
I put in a vise and applied sticky tape around the bezel, sticky on both sides. Then I put a nylon baggage strap around the bezel and twisted counterclockwise this with my biggest wrench/pliers. You need to hold the wrench horizontally. A makeshift strap wrench. I was incorrect about the Lux readings before, checked my numbers after work. Throw should be 4700 Lux @ one metre with new alkaline cells (IKEA brand). I did confirm this again with my Lux meter just now.
Stefan
Edit,
Sorry for invading your thread, couldn't resist a beamshot (or two). Exposure 125/1000, f 2.8. 3 metres. Cree X-RE P4 WC
Exposure 8/1000, f 2.8. 3 metres.
Looks like I could project a 1980's space invader onto my neighbour's roof at night :naughty:
Yeah, that you could. And on your next, next, next neighbours roof at that. It easily throws 100 metres.
There are some things that are very important for this mod to work. First you have to trim the star (if you use a star) because the inner part of the bezel pushes down the led pill for contact, and the star is to big to fit in this inner diameter of the bezel.
Trimmed star:
Then you need to enlarge the hole into the black reflector shaped piece of plastic just enough so the Cree's metal ring fits through the hole. This way you use this hole to center the star when the thermal epoxy hardens. It also pushes the star down when screwed down tight.
Soldering is easy, just use the existing leads. The leads are even marked + & - where they are attached to the driver circuit board. Just for fun I tried the optic with another light that I have modded with an SSC P4, Liteflux LF1. The led in that light is driven harder than the Aurora but throw is visibly less with the SSC P4 in this unscientific experiment. I recommend to use an Cree X-RE with this optic, it seems to throw much better.
Stefan
Excellent Stefan, really good pictures. I'll fit the Cree :)
I'm sure lots of people have this light, but have not been able to do anything with it.
What did you end up doing with the Jupiter LED, nothing?
I did this mod in early January, but never posted it because I thought: Nah, no one have this strange light. But it really shines with an Cree led in it.
The Nichia Jupiter lives in my "old led storage section" of my led modding toolbox. I have modded all my led lights with either Cree X-RE or SSC P4 U bin. I got the idea to use the Jupiter in a bedstand 0.5 watt Nuwai, but it wasn't worth the trouble. And I do like 0.5 watt Nuwai at night because it produces maybe 10 very blue Lumens, which is perfect for indoor navigating when you wake up and have to find your way to "the room".
Stefan
One last question - since the reflector holds down the star, is it necessary to use thermal epoxy? I have ordinary heatsink transfer compound (not epoxy) - would that do?
What if you drop it? Could be goodbye emitter in a worst case scenario. Just use some ordinary household epoxy on the outer tips of the star to fix it in place, then use thermal compound in the center. I did this, I used Arctic Ceramique thermal compound in the center and Arctic Alumina epoxy on the tips of the star. All household epoxies I have seen can stand at least 100 degrees Celsius, so just use whatever you have. There is a cavity in the heatsink where the Nichia Jupiter is epoxied, I just filled that cavity with thermal compound, works great.
Stefan
hey Stefan. I got this light about a year ago when it was on sale in Target for mare 5$. I love the light simply because the spotlight has that perfect "moon" look to it. After you modded it, do you still get that clean, sharp edged spotlight or is it gone ( due to small modifications to the reflector ? )..
Also could you point out which star from DX did you use ? Did you have to mess with the circuits ( if any ?) or was is as simple as getting out the old led and putting the new one ? thanks!
They both work. If you want the clean projected die shape go with the Cree. Thats what I like with this, the projected "space invader" spot, the SSC is fuzzier in the spot. Either way you won't get the moon shaped beam if you mod it, it will be a throw light. With such a Cree star you should get an intense dieshaped spot.
Stefan
I wonder if you could somehow remove thee lens, put in another glass non magnifying lense and a reflector with a lux or cree instead. I like the form factor of this light but hate the spotlight beam.
