Roar Of Pelican VS Quad LuxIII (pics)
Turbo_E
Turbo_E
Well, not real scientific, but i recently built both of these badboys...well cuz i wanted to.
Camera: Casio Exilim Z57 factory settings, no flash
cloudy night, pretty much no image seen on camera witout any external light
Specs:
Quad Lux
[email protected] 2D host
4 Luxeon III emitters (SX1K bin)
Fatman Regulator @ 1 amp w/dimmer set on max output
Modamag 6AA holder and Powerizer 2300 mAh AA's - 7.2V
UCL lens
R.O.P.
[email protected] 3D Host
Modamag 8AA holder 7AA Sanyo 2300 mAh AA's + 1 dummy cell + 1 Dummy D cell - 8.4V
mag switch fix
Pelican Big D "High" bulb 24W
Borafloat lens
FiveMega Heavy Orange Peel aluminum reflector
Quad VS ROP
QUAD LUX VS ROP on a tree 20 ft up
Quad Lux VS ROP on my house
in the side of the house again lux VS ROP
and finally both on the ground
yeah the ROP pretty much p3ned the Quad Lux in every way but runtime
Delvance
Delvance
Sydney, Australia
Nice pics Turbo_E! Glad to see you are enjoying your ROP :grin2: . Wow, 7 Sanyo's on the ROP, that thing should be pretty bright! Usually people use 7 lower quality cells. Sanyos tend to hold their V better than most other consumer grade rechargeables.
When you said factory settings for the camera ? Did you mean you let the camera automatically determine the settings or did you set the exposure etc ? Because if it was indeed automatic settings, the camera will actually adjust it's exposure rate according to how much light was on the photo area, in effect...making two different powered lights seem similar output. Just curious because the ROP should be absolutely obliterating the LED [email protected] hehe.
I might just have to try 7 AA's on my 2D ROP hrmmm.
eebowler
eebowler
Trinidad and Tobago.
I somehow only see one light in each picture... Thanks for the comparison though.
Delvance
Delvance
Sydney, Australia
eebowler,
I'm also seeing one light in each photo. I'm pretty sure we're seeing correct. I think Turbo_E took individual photos of the beams but on the same target.
KevinL
KevinL
At World's End
I just checked the EXIF data in the images he provided, they are directly comparable since the settings seem to be locked for all shots - f/2.6 and 1/8 sec.
We did this test one night too, with a 3xLux3 (my Mag3X) vs my ROP high. The Mag3X provides a very nice even flood, but the hotspot is not as concentrated because of the 3 smaller reflectors. The ROP collimates a little better being a single point source.
The 24W high bulb, especially when overdriven, is known to deliver quite a huge amount of light.. still outclasses the LEDs. The LEDs would win against the 11W low output, though.
wtraymond
wtraymond
Milwaukee, WI
I think you guys just need to scroll over to the right. The ROP images are on the right. If your screen is only set to 800x600 then you need to scroll over.
Turbo_E
Turbo_E
yes^^^ it just looks blended together cuz its dark, i'll fix it
not the pics are actually darker than they seem. the ROP puts out monster light
eebowler
eebowler
Lovely! I see two pics per target now. :) WOW! I need to get me a ROP really soon!
Turbo_E
Turbo_E
just a note to whoere is considering building a ROP:
don't expect super runtimes. this light makes a massive amount of heat and light.
for excellent white light and long runtimes, go for a Luxeon mod instead.
to burn the flesh off an attacker, build a ROP :D
S
Solomon MK2
Australia, Central Coast
It seems like my EL Tristar is way brighter than your QUAD!!!
But it could just be the exposure setting...
Delvance
Delvance
Sydney, Australia
91101 said:
Try it, you'll like it...:grin2: That's the way I run mine....
Just started my uni mid session recess today and i've got nothing to do today. Think i will give it ago :D i'll compare it to my ROP LE large and see how the 7AA one fares mhm.
Similar threads
D
Replies
Views
1K
Dukester
D
W
Replies
12
Views
4K
Icebreak
Icebreak
D
Replies
94
Views
39K
bykfixer
bykfixer
