I am concerned about the ID of the battery holders. In one part of the thread it is stated in a list that the battery compartment tube ID is 18.5mm. I searched for the NCR18650B and find the OD as 18.4 +-0.3. Do you think the battery compartment tubes could be bored out by 0.2mm without damageing the light?
I know the Fenix 35 u2 has a battery carrier and that is not preferable, but could it probably take the larger 18650B cell.
I found the standard 18650 cell size to be 18mm x 65mm and the larger capacity cells are longer and larger diameter than 18mm x 65mm.
If the battery compartment could not be easily enlarged (bottom plate removed, does that give you full access to the battery compartment so you could enlarge the bore diameter) then that could be a restriction of the larger cells now and even larger designs in the future.
Bob Weis
Bob Weis
