Romisen RC-C8 flood to throw // high, med, strobe // 3xAAA
MojaveMoon07
U.S.
As I mentioned in the RC-27 thread, I would prefer a multi-stage all-flood budget-priced flashlight. While I couldn't find any feedback about the RC-27, I found a smattering of comments about the RC-C8. However, due to my limited experience and knowledge about flashlights, the comments about the RC-C8 gave me a mostly incomplete understanding of the it.
I would be grateful if any (past or present) owners of it could comment about it; the version of it that I am interested in is what Shiningbeam.com is selling. Also, approximately what runtime can I expect for the high and medium modes ? Since my recharger is the one that came with the package of Sanyo eneloops sold at Costco, I can't recharge one battery at a time. If the runtime is too short for the RC-C8, then maybe it'd be (too) inconvenient to be regularly recharging the batteries for it.
Also, I don't understand what the commenter (below) is trying to explain when he spoke of a "massive darker circle of light surrounded by a brighter circle of light".
- WC tint Cree XR-E R2 LED
- High, medium and strobe, about 30% brighter than the regular model
- 5.1" x 1.1" x 1.3"
- 3.5 oz
(link)
Light has mode memory, it starts always from previously used mode.
Modes are 100-50-slow strobe.
I would say theres a noticeable difference with 100% to 50%, yet you cannot call 50% a "low" mode by any means. It still is relatively bright and usable with 50% but runs very long
(link)
The RC-C8 has a bigger lens and tighter beam, so it should throw better, although mine never quite brings the image of the die to focus.
(link)
I have the rc-c6 and rc-29 and like them both alot but the rc-c8 didn't get very good reviews. Still worth checking out though.
(link)
i have three Romisen adjustables that i purchased through Shining Beam. they're great little lights but produce this massive darker circle of light surrounded by a brighter circle of light if its anywhere within "mid-range"....its been driving me nuts because thats generally the most practical setting. i bought their RC-C8-II rather recently hoping this larger one might be better but it has the same pattern...and its not really any brighter than my 3V Romisen (RC-C6 i believe) [...]
If I remember correctly, RC-C8 has (when Zoomed for throw) more "corona" around the spot compared to smaller RC-C6.
I would say RC-C8 is brighter than RC-C6 in FLOOD MODE. It is harder to say which throws better.
RC-C8 has bigger lens but it also has longer threads for zooming a throw spot. I think it loses some of its lumens while lens goes so far away from emitter :shrug:
I tested runtime on 50% med. In floodmode, I found it quite useful.
I left it on for night, it went ~8 hours with "Trustfire flame, 2400".
I would say it´s a good light if you use the flood most. For thrower I found it a bit frustrating to turn its head quite many times to zoom... Slideable flood-to-throw lghts are more convenient.
On the other hand, this has the greatest versatility batterywise.
Size is quite compact IMO, also.
Forgot to answer to this.
I believe he means, that that somewhere between maximum throw and maximum flood, the beam is not even in brightness.
I mostly use the full flood, very rarely that "somewhere in between" -mode.
But it is true, beam is ringy or not perfectly smooth and balanced.
Thank you very much for your detailed and thorough reply
My Sanyo AAA eneloops say 750 mAh on the label. Since that's approximately 30% of the capacity of your battery, does that mean I should expect a runtime of 30% of your runtime, i.e., a runtime of approximately 2.6 hours on three 750 mAh eneloops ?
I´m not a pro in calculating or estimating runtimes but because of different chemistry and different voltage. Maybe there´s info in battery & electronics section, how to calculate it.
I would guess though, that something around 2h would be expected.
