hmm...ive been through two romisen rc-f4s. both suffer from this problem where sometimes the flashlight would go to a very dim mode and sometimes it works perfectly fine. sometimes when i change the orientation of the batteries such as take out one battery and rotate it 180 degrees, it works fine. sometimes i do not need to change the orientation of the batteries, just loosen and tighten tailswitch again and it works fine. sometimes when i loosen and tighten, there is a quick flash at full brightness followed by dim mode, as if my batteries are low. batteries that i am using are trustfire 3.7v protected rcr123a with gray wrapping found on Dealextreme. the batteries work no problem on a romisen rc-n3. just a note, i have clean the threads and ends of flashlight multiple times.
pics:
working fine:
dim light (my fenix e01 is even brighter than this):
weird washer found under switch:
pill:
youtube video showing problem: http://www.youtube.com/watch?v=82f-BPqmO-0
pics:
working fine:
pill:
