It wouldn't be an easy mod. The hole in the reflector would need to be enlarged to fit the bulb and base. Then, you would need the compatible base, which does not exist, so you would have to fabricate your own.
FM was selling an adapter to use bipin bulbs, a much better solution as no reflector mods are required. I believe he is out of them but considering another run.
