Mjolnir
- Joined
- Dec 19, 2008
- Messages
- 1,711
I recently built an ROP using this reflector. While the bulb itself fits through, the opening seems to prevent it from going as far out into the reflector as it normally could. The ROP also has far less throw than I had expected based on beamshots posted here by various people. I realize that they are using different reflectors, but they are all similar in size. I suppose that I could have simply underestimated the hotspot size... However, I have no way to determine if the bulb is focusing as well as it could in the reflector.
Does anyone have any experience with using the reflector with the smaller opening vs. the larger one? Could the reflector with the smaller opening reduce throw? It is MOP, but I was under the impression that a textured reflector wouldn't reduce throw all that much (especially since the reflector is so large).
My malkoff maglite easily outthrows the low bulb, and probably the high bulb as well.
