RovyVon A8 Y Flashlight Review
zeroair
I humbly submit this post for consideration in the review category
This content originally appeared at zeroair.org. Please visit there for the best experience!
There was a group buy organized on reddit of this special run of the Aurora series… It was this Nichia version, with a modified UI. I got my copy recently and I’ve been playing with and testing it. It’s similar enough to the older ones that this review will be brief[er] on text, but with description of differences.
Official Specs and Features
Here’s a link to the official product page.
Versions
Of this exact A8, there are two options. They differ only in the secondary emitters. The one here has red, blue, and amber. There’s also an option with UV, white, and red. Outside of the A8, there are many lights in the Aurora series, which I won’t get into fully- there are special metal, special finish, different secondary, no secondary, etc. There are plenty of options in the Aurora series!
Price and Coupon
The price of this model is $46.95, but can be discounted with the coupon “zeroair”. Buy it here!
Short Review
I liked the Aurora series, and I like it even more with Nichia. I will gladly take lower output in exchange for a Nichia 219c emitter. The new UI is fine, and I appreciate the lower low. The light seems to have picked up some unfortunate PWM on the lower modes, but I hear RovyVon is getting that sorted out.
Long Review
What’s Included
  • RovyVon Aurora A8 Keychain light
  • Metal necklace
  • Pocket clip
  • Charge cable (USB to micro-USB)
  • Lanyard
  • Manual and paperwork
Package and Manual
Nothing new about the package!
The manual is updated for this specific model, with a runtime graph specifically for the 219c.
The manual’s good, and is a single A4 sized paper.
Build Quality
Nothing at all unexpected from this updated Aurora. The body is a new poly – completely clear and not tinted. I think this was because of the UV option, to be certain that the body doesn’t impede the UV. (To wit: RovyVon has considered the fact that polycarbonate blocks UV, and has taken care to prevent it in this light).
Size and Comps
Officially 2.12 x 0.57 in, and 0.03lbs. I weigh it at 11g. Eleven grams! This clip adds about 1g, so 12g total with clip.
Retention and Carry
A very good way to carry this light is the included chain. It’s unusual that this thing is included, but it attaches securely, and carries well on the neck.
The other option is the pocket clip. It’ll attach on either side of the light, and in two positions, and also in either orientation. Very versatile.
This versatility allows the A8 to clip on the bill of a cap in a useful orientation, for example.
Power and Runtime
The battery is internal, and built in. Ie, it’s permanent, and can’t really be swapped. I performed a runtime on the highest mode. As expected (per testes on the other Auroras), the output drops dramatically and quickly
In my tests (which go down well below 10%), the light never shuts off. Output also doesn’t quite hit the claimed 350 lumens, as measured on my device.
I also performed a runtime on the second highest mode. Output steps down quite quickly with this mode too, and after the stepdown the output is more or less the same.
Of course with a built in cell, the light also has on-board charging. A cable is included, and is powered by USB.
The micro-USB port is covered by a little rubber plug, which is the same as on the E300S.
Below is a charge graph. Nothing unusual really, except that the CV phase is quite long.
PWM
PWM is quite noticeable on the lower modes, and can even be seen on the third mode. It’s completely absent on the highest mode.
Note the scale below – 2ms – and compare it to the E300S reviewed just the other day, where the scale was 50us. (50 microseconds). Unfortunately I find the PWM on low to render the lowest mode practically useless.
For reference, here’s a baseline shot, with all the room lights off and almost nothing hitting the sensor.
User Interface and Operation
There’s one switch on the A8. It’s a clicky e-switch. The second biggest difference in this and the other Auroras is the UI. This one has been reworked (based on reddit users requests!)
Here’s a UI table!
StateActionResult
OffClick No action
OffHoldMomentary Turbo
OffDouble ClickMoonlight
OnClickMode Advance (LMH)
OnHoldOff
On (Over 3 minutes)ClickOff
OffTriple ClickRed/Blue Flash
Red GroupClickRed Advance (Red/Blue > Red Only flash)
OffFour ClicksAmber
Amber GroupClickAmber Advance (Amber steady > Amber Beacon)
LED and Beam
Everything’s the same about the beam of the light except the emitter. The emitter has been changed to a Nichia 219c, 4000K and >90CRI. The optic still gives a beam with mostly spot and a little spill.
The side lights are quite bright…. in fact I would love to have access to lower side modes. And steady red/blue, not just flashing.
These beamshots are always with the following settings: f8, ISO100, 0.3s shutter, and manual 5000K exposure.
Tint vs BLF-348 (Killzone 219b version)
These are the same shot but with different settings – I thought the second one was easier to understand. (The top one is included just because it’s the same settings as all the others I’ve done.)
I compare everything to the Killzone 219b BLF-348, because it’s inexpensive and has the best tint!
The Big Table
RovyVon Aurora A8 Y
Emitter:Nichia 219C
Cell:Internal
RuntimeChargetime
LVP?Warning
Power off Charge Port with no Cell?
Claimed Lumens (lm)350
Measured Lumens (at 30s)224 (64% of claim)*
Claimed Throw (m)
Throw (Calculated) (m)59.8
Candela (Calculated) in cd (at 30s)81lux @ 3.322m = 894cd
All my RovyVon reviews!
* Standard measurement disclaimer: I am an amateur flashlight reviewer. I don’t have $10,000 or even $1,000 worth of testing equipment. I test output and such in PVC tubes!! Please consider claims within 10% of what I measure to be perfectly reasonable (accurate, even).
Conclusion
What I like
  • Nichia Emitter! Yay!
  • Amber side light – it’s my preferred secondary!
  • Same good build quality as the other Auroras
  • Can be used on the bill of a cap for running or hiking etc.
  • Micro-USB charging works well enough
What I don’t like
  • PWM
  • Red/Blue flashly only, no steady modes for those
  • Battery isn’t replaceable.
Notes
  • This light was provided by RovyVon for review. I was not paid to write this review.
  • This content originally appeared at zeroair.org. Please visit there for the best experience!
  • Whether or not I have a coupon for this light, I do have a bunch of coupons!! Have a look at my spreadsheet for those coupons. It’s possible to subscribe and get notifications when the sheet is edited!!
Snapper314
Good review!
I have been carrying a RovyVon Aurora A2 for about a month and it's been excellent. I've only considered the metallic ones since the primary issue reported (beyond the small & non-replaceable battery) is that the non-metallic bodies have cracked on occasion.
zeroair
Good review!
Oh interesting, I didn't know about the cracked bodies. But I can see how it could happen. The plastic is the hard variety (not softer/pliable).
