kuksul08
I have two questions.
1. I'm putting a circuit that I built inside some 1" square aluminum tubing. There are dozens of solder connections sticking out from my perforated circuit board. I have some bicycle tube rubber (~1/16") that I cut into a rectangle and placed over the bottom of the board to insulate it from the aluminum housing. Is rubber a suitable electrical insulator, or will it cause issues?
2. Same circuit as before, I have two TIP122 transistors that are a little too tall. Is it okay to trim the metal on the heatsink part of it? I was planning on cutting through the center of the hole.
Thanks!!
Thanks!!
