Roy
Farewell our Curmudgeon Administrator
This runtime plot is for a mod by CPF menber d'mo that uses a 1w LS led in an ARC AAA flashlight. The first plot uses a AAA alkaline battery. The second plot uses a custom made body for the ARC AAA head that uses a N size battery.
Equipment used is a Extech Mdl 401021 Light Adapter into a Radio Shack 22-805 multimeter with a PC interface that is using ScopeView software (V 1.08).
The vertical axis is in 12mVDC per division and is equivalent to 12Fc @ 1Ft per division. The horizontal axis is 10 minutes per division.
Be aware that your actual battery milage mayvairy from that inddicted by this runtime plot.
ARC AAA with the ARC-AAA-LS mod by d'mo
Runtime to 50% max bright = 29 minutes
NARC-LS (jet22's N size battery tube with d'mo's ARC-AAA-LS head.
Runtime to 50% of max bright = 6 minutes
