Roy
Farewell our Curmudgeon Administrator
This runtime plot is for the Bowling Pin Light. This light uses one CR123 Li battery. A Surefire CR123 was used for this test.
Equipment used is a Extech Mdl 401021 Light Adapter into a Radio Shack 22-805 multimeter with a PC interface that is using ScopeView sortware (V 1.08).
The vertical axis is in 6mVDC per division which is equivalent to 6Fc @ 1Ft per division. The horizontal axis is 15 minutes per division.
Be aware that your actual battery milage may vary from that indicated by this runtime plot.
The runtime to 50% max brightness = 4hr 15min
