Run-Time Plot - MadMax+ Q3 1x123
Candle Power Flashlight Forum
Help Support CPF:
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
This runtime plot is for a MadMax+ Q3 LS adapter that is using one SureFire 123 Li battery.
Equipment used is a Extech Mdl 401021 Light Adapter into a Radio Shack 22-805 multimeter with a PC interface that is using ScopeView Software (v 1.08).
The vertical axis in in mVDC and is equivalent to one footcandle per mVDC. The horixontal axis is 15 minutes per division.
Be aware that your actual battery milage may vary from that indicated by this runtime plot.
The runtime to 50% of max brightness = 83 minutes
This runtime plot, using one 123 LI battery, was done using the same MadMax+ Q3 adapter that was used to determine the runtime using 2xAA Alkaline batteries.
