I was shopping for a 24 volt inverter for my wheelchair so I can run it right off the batteries than a 12 volt one to run off of my 24-12 volt converter so I would loose less in conversion and wouldnt be limited to 23 amps on the 12 volt side, but 70 of the wheelchair battery boxes. Anyhoo, I found a few 24 volt inverters that double as a charger. In fact i think home power had an article on how to make your own back up supply using a cart multiple deep cycle batteries and a larger inverter taht doubles as a charger and it automatically flipped between charging and running.
I do agree with the heat thing. I have a small inverter, 30 watts max, no fan and man, it gets too hot to touch after 15 minutes powering my 19 inch tv. I have a 450 watt unit with a fan and man, it works well and cool.
