HighlanderNorth
OK. If you have one of the many LED lights that are designed to run on either NiMh or Li Ion batteries, what will be the differences in runtime if using the light on the same modes when comparing the Li Ion vs. NiMh batteries. Lets say you have a Zebralight SC52. Its listed to use either an AA battery or a 14500 Li Ion. If you were to install an Eneloop 2000mah AA battery one day, then a 14500 Li Ion battery with 750mah capacity the next, and you experimented by running the light on the exact same modes one day til each battery was run down to its safe lower limit, how would the run times compare as long as you were comparing the low and medium modes, not the much higher turbo mode that you would likely see using the Li Ion battery?
The Eneloops are 1.2V nominal with 2000mah capacity and the 14500 is 3.7v nominally with just 750mah. But I assume the additional voltage would essentially make up for the lack of capacity if used on the same lower and medium modes. How does that work out? For instance, lets say the medium mode you were comparing was 100L and the low mode 25L approx. on both batteries....
Would the run times be fairly close when comparing these 2 types of batteries on the same modes?
