Buy the Two MJP light's and get this VINTAGE CPF LED Ball Point Pen ( you will never see one of these again) gotta have for the complete collection for $175.00 + $5.80 shipping USPS
For sale : 2 ARC MANIA / MJP Extreme Micro's ~~~ HAIII (green) :
NOTE: PRIMARY BATTERIES ONLY, NO RECHARGEABLES IN THIS FLASHLIGHT, IT WILL BURN OUT. The E-Micro is unique and tiny. It is a custom light smaller then any converter based CR2 light. It has ultra clear lens, metal reflector, and hard anodizing. The body is made of 6061 high-grade aluminum. Extreme Micro CR2 LED flashlight 6 levels of light: low, medium, high, strobe, beacon, SOS no memory. T6061 aircraft grade aluminum Type III hard anodized olive drab color Mineral glass Osram Golden dragon LED with lens 120 lumens/watt, 5000K tint Viewing angle of beam: 20 degrees Beam is smooth and flawless. No rings, circles or hotspots. Drive current to LED: Low - 30ma, medium - 180ma, high - 450ma, strobe, beacon, SOS - 450ma Twist/on/off change mode Runtime: 20 hours in low mode, 1 hour 20 minutes in high mode. Tested with Energizer CR2. Can use only CR2 lithium battery Length: 44mm Thickness: 22mm Assembled in Japan The Extreme Micro will always start from low mode. Twisting the battery barrel on/off within 3 seconds after turning on, will change modes enabling to shift through all 6 levels of light. As long as the light is well taken care of with the o-ring lubed from time to time, the Extreme Micro should last a lifetime. |
The other HA dark red
is Seoul P4 @ 440Ma single action 1 level of brightness
FREE PELICAN 1200 CASE also
