SAFT Li-SOCI-2? (Disregard answers found)
RA40
So. Cal
[size=+2]UPDATE found my answers with a little bit more searching.[/size]
Was randomly browsing looking at Li-ION cells and came across these. Would like your thoughts?
http://www.saftbatteries.com/130-Catalogue/PDF/LS_17500.pdf
Saft LS 17500 Primary Lithium Battery
# Key features:High and stable operating voltage
# Low self-discharge rate (less than 1% after 1 year of storage at + 20°C)
# Stainless steel container and end caps (low magnetic signature)
# Non-flammable electrolyte
# Compliant with IEC 86-4 safety standard and EN 50020 intrinsic safety standard
# Underwriters Laboratories (UL) Component Recognition (File Number MH 12609)
Specifications:
# Nominal Capacity: 3.4Ah
# Nominal Voltage: 3.6
# Operating Temperature Range: -60°C/+85°C (-76°F/+185°F)
# Dimesions: 0.67in x 2.00in
Re: SAFT Li-SOCI-2?
Specifications:
They're for very long duration of very small discharge.
Capacity loss sets in at 15mA.
At 200mA (0.2A) capacity is reduced to 30% and rated maximum peak current is 0.25A.
vortechs
Tucson, AZ
Hi RA40,
Questions about 3.6V primary lithium batteries (SAFT, TADIRAN, etc.) are fairly common on the forums. It seems that every new flashaholic eventually encounters them and wants to know how suitable they are for flashlight use. Since you just found some of the info by searching, you could do CPF a big favor by summarizing the info available and providing links to it. :)
monkeyboy
UK
Saft's Lithium Sulphur Dioxide (Li SO2) cells are more suitable for flashlights since they can handle higher currents. However they are 3V and have lower capacity.
