Sold/Expired SALE: JM-PhD-D1 PWM Hotwire Regulator BATCH 2
JimmyM
Boston, MA, USA
I’d like to announce the BATCH 2 sale of the JM-PhD-D1.
At long last batch 2 of these is ready for sale.
This is also going to be the last batch for a long time, if ever.
If you want to have a look at the original sale thread, it can be found HERE.
Multi-level operation is now available.
It's a lot of information, but please read through it, it will answer most of your questions.
The Basics...
What it is: The JM-PhD-D1 is a voltage regulator for hotwire flashlights that uses an Atmel Tiny44 microprocessor to measure battery voltage and adjust the output using 12-bit PWM to maintain constant RMS voltage to the bulb.
Where it goes: It’s designed to fit under the aluminum base of a KIU socket for a D cell Mag body. With its current software version, you make adjustments via 2 onboard pots, so drilling 2 holes in your KIU base will make things a lot easier for adjustments after it is installed. See below for drilling a template and installation documents..
How it works: It uses PWM (Pulse Width Modulation) to control the RMS voltage to the bulb. By turning a switch (an FET) on and off several times (244Hz) a second, the "effective" voltage that the bulb sees can be controlled. The bulb is still receiving the full battery pack voltage while the switch is on, but it’s not on for the whole time. The frequency of the PWM and thermal mass of the filament prevent flicker. It can only control output voltage less than or equal to the pack voltage. It cannot boost battery voltage.
Can it be used with LEDs? Since the full battery voltage is applied to the output while the FET is on, it could only be used with LEDs if the full battery voltage could be applied to the LED without damage. Also, since LEDs turn on and off faster than a filament, you will probably notice flicker. So it is my recommendation that this not be used with LEDs.
What functions / features exist? I have tried to future proof the hardware design as much as possible. There are 2 11-turn pots onboard for adjustment. I’ve used 11-turn pots to allow very fine adjustment. There are also 3 additional pads that connect to unused pins on the Tiny44 to allow the future use of pushbuttons or LEDs for things like mode selection, voltage level selection or adjustment, low battery indication, rotary encoder, etc, etc, etc. There is a 6-pin programming header onboard to allow for software updates. The programming header is female to avoid shorts, so a male-male adapter is required to connect it to the programmer. I have a bunch of them and will include one with each order until I run out.
Current Software Functions:
Standard Mode:
This mode is designed to have power to the "control power" connection switched on or off by the existing Mag switch (See wiring diagrams). When turned on, the regulator will softstart to the set voltage. The 2 pots onboard are used to adjust output voltage and low voltage set point.
Pot 1 (Vbulb): Adjusts desired output voltage between 0 and 40V. (Clockwise increases) If you set the output to a voltage above the battery voltage, the FET will be turned on 100% of the time and you will only be able to get the pack voltage.
Pot 2 (Vlow): Adjusts low voltage set point. (Clockwise increases) When the low voltage set point is reached (by falling pack voltage) and maintained for 0.125 to 0.5 seconds (configurable by the user), the output will be reduced and ramped up and down between 2 lower percentages of the set output voltage. It will pulse. If the batteries recover, the regulator will ramp voltage back up to the set point.
Low voltage actions: The user can select how the regulator should behave once in Low Voltage Mode. The light can pulse OR dim.
Low Voltage shutdowm options: The light, once in low voltage mode, can either shut down after a selected period of time, or can shutdown once the battery voltage has fallen to a user selected percentage of the Low Voltage warning point. or BOTH which ever comes first.
Over temperature warning: At a user selected temperature (50, 60, 70, 80C), the light will dim to 35% of it's set voltage.
Over temperature shutdown: If selected by the user, the light can shut itself down if in Over temperature mode for a period of seconds selected by the user.
S-Curve softstart ramp: This function is not an option, it's more of a feature. It starts the bulb slowly at first, then ramps quickly to a point less than the regulated voltage then ramps slowly to the target voltage. It's designed to improve bulb care and hopefully blow up fewer bulbs.
Soft Start speed: 3 speeds are available. Slow, Medium, or Fast.
..Slow is best for users that are pushing the bulb very close to its flash point. It's a gentle start.
..Medium is a good multi-purpose start.
..Fast is very fast. The bulb comes on almost instantly.
When the light shuts down due to over temperature or low voltage it's not completely shutdown. It's actually asleep and will consume 0.1mA of current.
Multi-Level Mode:
This mode is designed to have battery voltage connected all the time to the "control power" connection (See wiring diagrams).
The existing Mag switch will need to be modified for Momentary operation. The Mag switch will then need to be connected from the A2 pad on the board to the Battery Negative ( B- ) connection. (See wiring diagrams).
The Mag switch will now control multiple levels of output selected by the user.
These levels are percentages of the voltage set using the Vbulb Pot. So, for example, Level-1 can be 87% of Vbulb, Level-2 can be 94% of Vbulb, and Level-3 can be 100%.
From the Off condition, 1 click will turn the light on to Level-1. Another click will advance the light to Level-2, another click will advance the light to Level-3, another click will return the light to level-1. click & hold the button for 1 second and the light will shut off.
The click&hold can be done at any time. From off, 2 quick clicks goes to Level-2. 3 quick clicks goes to level-3.
The voltage percentages for the different levels are selected by the user (either when ordering, or by re-programming it later). They can be in any order you want. You can have a light that sequences through low, med, high or high, medium, low. The regulator can also be set up for just 2 levels or just 1 level if you want.
Pot 1 (Vbulb): Adjusts Maximum output voltage between 0 and 40V. (Clockwise increases) If you set the output to a voltage above the battery voltage, the FET will be turned on 100% of the time and you will only be able to get the pack voltage.
Output level percentages: The user can select (while ordering or re-programming) what percentage of Vbulb each level can be.
Soft Ramping: This option enables the regulator to ramp softly to the next level
When the light is shutdown by the user or due to over temperature or low voltage it's not completely shutdown. It's actually asleep and will consume 0.1mA of current.
Update to firmware (2012-08):
I have added a "VLOW_Latch" function like the X1 regulators have. If this option is enabled, when the low voltage warning is reached, the warning will not reset even if the battery voltage recovers. This will prevent an up/down ramping of output if the battery is on the edge of the low voltage set point.
I have updated the firmware on my support web site linked elsewhere in this post.
Setting the voltage: Any voltage setting must be done with a bulb or other load in place in the socket. A 5W 1K Ohm resistor will work in place of a bulb. A True RMS reading DMM is best (Like the Fluke 189), but it can be done with an average reading DMM using the following calculation.
You need to now the following:
Vin = Battery voltage under load
Vrms = Your desired RMS voltage (The effective voltage to the bulb)
Vavg=(Vrms^2)/Vin
Once you’ve calculated Vavg, turn the voltage adjust pot until your meter reads the Vavg voltage you just calculated.
Setting the low voltage point is a little trickier. First turn the Vlow adjustment pot counter-clockwise several turns. You need to let the batteries drain to the voltage you want them to shut off, then turn the pot clockwise until the light begins to pulse. Then adjust slowly around the point where the pulsing began to fine tune the adjustment.
I will make the initial adjustment per the buyer’s specification.
Any adjustments for voltage can be done with the 2 onboard pots. You do NOT need a computer & programmer to make settings changes. The programming header on the board is for future software updates and for those of you who want to do customizations to the software. All you need with the current software revision is a very tiny screwdriver. Adjustments can be made with the light on. If adjusting the pots while the regulator is installed, NO special precautions need to be taken to avoid touching the aluminum base with adjustment screwdriver.
High temperature indication: When/If the microprocessor reaches a user selcted temperature (50,60,70,80 deg C), the voltage will be ramped down to 35% of the set output and will remain there until power cycled.
Specifications:
10/12-bit regulation: Gives 0.04V resolution while setting the regulator, but is extremely accurate at holding that voltage. Typically better than 0.03V
Minimum voltage: 5.2V
Maximum voltage: 40V
Maximum continuous current: 13A (Lux Luthor has performed testing up to 15 Amps without high temperature shutdown)
Adjustable output range: 0V to battery pack voltage.
Leakage current:
..Using the "Standard Mode": When OFF, the driver will leak ~1 uA of current.
..Using the "Multi-Level Mode": When "OFF", the regulator is sleeping and uses 0.1 mA of current.
Testing done so far:
64625 @ 13V with 17V input creates very little heat in the FET.
64447 @ 18V with 39.9V input creates almost no temperature increase in the FET at all.
This unit will not handle the 600+ watt lantern style lights.
OK. Now the bottom line.
Update: 10/21/12
Too many projects not enough time or money. You understand.
So, from now on, these are $30 each plus shipping instead of $40.
Buy 3 or more, and they're $27 each plus shipping.
If some entrepreneur-ing individual wants to buy a whole bunch, IM me and we can work something out.
Shipping within the US is by US Priority Mail ($9 per order, up to 10 units).
First Class Mail International is $12.
Any expedited shipping will need to be worked out on a per order basis.
Each order will include one male-male programming adapter.
PayPal to: [email protected]
International orders using foreign currency, add 4%
Credit Card orders add 3%
-------Ordering Option---------
For "Standard Mode" (Default Values are Bold)
Operation Mode: Standard
Vbulb: Your desired Vbulb voltage
Vlow: The voltage where the low voltage warning should kick in.
Softstart: Slow, Med, Fast
Low Volt Warning: Pulsing or Dimming
Low volt shutdown: Timed:# seconds, Undervolt: X%, or Both (Both, 30 Seconds, 94%)
VLOW_Latch: Enable/Disable
Over Temp trigger: 50C, 60C, 70C, or 80C
Over Temp Shutdown: Yes/No, If, Yes, Y seconds: (30 Seconds)
Response: 1/8, 1/4, 1/2 second
For "Multi-Level Mode"
Operation Mode: Multi-Level (Default Values are Bold)
Level-1: 18-100% (87%)
Level-2: 18-100% (94%)
Level-3: 18-100% (100%)
SoftRamp: Yes/No
Example order will list the number of units, the set voltage, low voltage point, and options.
Also include the shipping method if it differs from US Priority mail. International orders can be shipped by First Class Mail International and is also covered by the standard $7 shipping.
Please copy and paste the text of your CPF "I’ll take it" post into your PayPal payment along with your CPF handle. You NEED to include your CPF handle.
Send PayPal to:
I’ll take:
3 drivers
#1
Vbulb: 7.2V
Vlow: 6.6V
Softstart: Med
Low volt shutdown: Both. Timed:30 seconds, Undervolt: 87%
Over Temp trigger: 60C
Over Temp Shutdown: Yes, 10 seconds:
Response: 1/8 second
#2
Vbulb: 13.4V
Vlow: 12.0V
Softstart: Slow
Over Temp trigger: 70C
#3
Vbulb: 13.4V
Vlow: 12.0V
Level-1: 80%
Level-2: 92%
Level-3: 100%
SoftRamp: Yes
Softstart: Slow
Low volt shutdown: Both. Timed:30 seconds, Undervolt: 92%
Total: $100 + $9 shipping (See updated pricing above)
This batch is 100 units. This will be the last batch of these for a long time if ever.
All support documents and code can be found below.
How to Load Firmware on your PhD-D1: Link
Firmware:
Rev3f: Link
Rev3h: Link
Rev4b: Link <-- Support for WS2812 LEDs (AKA NeoPixels)
Connection Diagrams:
Powering your D1 externally if programming when not installed: Link
Standard installation: Link
Multi-Level UI: Link
Assembly Instructions:
Drill Template: Link
Standard installation:Link
Multi-Level UI installation:Link
All options/features are available in the Rev4 code. Any one that wants to tweak their setting by re-programming the light themselves should download the most recent source code.
Detailed programming instructions.
An instructional document for the "Standard Mode" installation.
An instructional document for the "Multi-Level" installation.
A drill template for the KIU socket can also be found in the support site. You print the PDF at 100% size. Cut out the round regulator board outline. Then place the cut out paper inside the bottom of the KIU socket so the printing is visible. Line up the screw holes of the KIU with the screw hole markings on the paper and use a sharp object to mark the centers of the holes to drill to allow pot adjustments without removing the switch from the body.
JimmyM
Boston, MA, USA
Colonel Sanders: 3 units. Waiting for config & PP
secondtimearound: 3 units. PAID
gvp: 2 units. PAID
jaundice: 4 units. Waiting for config & PP
JimmyM
Boston, MA, USA
The updated firmware can be downloaded via my support site http://mysite.verizon.net/jminihane/id1.html
Colonel Sanders
ROLL TIDE!
I'll take 3! Gonna take me a bit to sit down and figure out how to properly order the thing with all of the options to go over.
BUT SAVE ME THREE! (Paypal will be coming shortly after I figure everything out.)
Colonel Sanders
ROLL TIDE!
Jimmy, what if I paid you for about a half dozen of these things but gave you the specs on most of them at a later time for a later delivery. Would that be cool? Of course there would be extra shipping charges involved. It's going to take me awhile to decide how I want all of these set. I only have a couple of them figured out so far.
JimmyM
Boston, MA, USA
Breathe, Colonel, breathe. I've got a hundred of these. Unless someone shows up to corner the market, you should have plenty of time. I'd rather not to do the "purchase and hold" again.
Phil Ament
Melbourne, Australia
I would definitely say that the Colonel is most probably just a little bit too excited because roughly only 10 minutes before his previous post he had just purchased this!
secondtimearound
I'll take 3 units. Specs and funds to follow.
Thanks Jimmy.
Doug
I'll take it:
3 drivers
operation mode: standard
vbulb: 8.3V
vlow: 7.2v
softstart: slow
low volt warning: dimming
low volt shutdown: both. timed: 30 seconds, undervolt 87%
overtemp trigger: 70C
overtemp shutdown: yes, 10
response: 1/4 second
Thank you.
CPF -- secondtimearound
JimmyM
Boston, MA, USA
Jimmy, are these any different than the previous batch?
Nope. Exactly the same design. However I had to use an International Rectifier FET instead of the Fairchild one used previously. The original one was discontinued. The IR units are pretty tough.
JimmyM
Boston, MA, USA
I'll take it:
3 drivers
vbulb: 8.3V
vlow: 7.2v
softstart: slow
Thank you.
Got it. I'll have these programmed and out early next week. I'm traveling for work this week.
gVp
msk.ru
Jimmy, i want to order at least one of this nice things.
but my modding skills are almost zero, so the question is - can i get from you the whole switch with socket for extra money?
if answer is positive, please PM me your conditions to think about.
thank you.
Colonel Sanders
ROLL TIDE!
I'd like to get some advice on where to set the voltage to FULLY maximize the output of an FM-1909 bulb. I want to take it right to the ragged edge...bulb life be damned! :devil: Jimmy? LuxLuthor? Anyone?
Justin Case
Lux's tests showed that the 1909 flashed at 13.0V. This is with a manual turn of the voltage knob for a bench power supply, essentially the ultimate soft start. Thus, I'd say that the absolute ragged edge is at Vbulb=12.8V. It is unclear, however, if the bulb will survive even with the Slow soft start setting on the JM-PHD-D1 regulator. If you want some reasonable probability that the bulb will survive, I'd try 12.0V and work upward to 12.8V. All with Slow soft start. When the lamp flashes, back off by a couple of tenths of a volt back to where the lamp didn't flash. That's probably your max setting.
I'm running my 1909 at 11.8V, with Medium soft start.
