ledfan
Paypal sent.
Help Support Candle Power Flashlight Forum
I plan to pocket carry but is there a band to use this as a headlamp?
Unfortunately, No. There is not enough room in the Pill to do it.My first real light is my mte p7-c. I think that's too blue, I don't really like the reddish color of cheap compact florescent bulbs ethier though. I can't get the ssc PDFs to load on my iPhone but I read the cree PDF link. That spectral distribution chart shows the cool whites as high in blue low in red the warm white as high I'm red low in blue and the neutral white as medium in both.
If I turned the light and handheld for a minute how many lumens would then be at 1400ma(300-400) 2800ma(600-800) and 3800ma(900-1000)? Is there a efficiency point at which more current means alot more heat and little more light? 1400mA is a good balance of efficiency and power
Lastly is it possible to add a protection ic to the light itself so I could use quality high capacity oem cells?
Is there anything between the pill and the top of the battery?
If I turned the light and handheld for a minute how many lumens would then be at 1400ma 2800ma and 3800ma? Is there a efficiency point at which more current means alot more heat and little more light?
i had a nice reply lined up for you last night. 3 paragraphs long and i lost it because "page not found" or something like that and then lost the whole post. n-e-ways, we'll see if i can help any.
2800 gives you ALMOST double the light of 1400 but not quite, making the 1400 more efficent but the 2800 still way cooler. above that, lumens doesn't rise as fast to be practical. number one, the led is less efficent at high drive currents, and number two, dont forget some batteries, even lithium, become less efficent at higher drive currents. i'd recomend the 2800mah if efficency is even slightly a concern.
to further back up my "dont buy the 3800mah" point, with pwm regulation, even on low and medium modes which wont necessarily drain the battery at unreasonable levels, it still drives the led at the unefficent rate of 900mah per led, at a super fast strobe, so fast you cant tell its a strobe, it just dims the light. at least with the 2800mah, you'll have decent efficency still with the led's just a little out of their peak efficency. (edit: only applies to the 5 mode driver, sorry)
what do you mean? my strobe
works just fine with the 3800mA option :thinking:
as far as the mce vs p7, neither will show any red, so dont worry about that. mce will have better color rendition and a warmer yellower-white, whereas the p7 wont be too far off your mte but probably a touch to the white side due to the quality of the builder. have fun with whichever one your choose.
Greetings,
I'd like to order 3 of the following lights:
Option 2, P7 with 2800mA board $120 x 3 = $360, (includes the 2800 board?)
Also, would the 2500mA Trustfire batteries (and charger) you offer work with the above? Or do I need AW protected or IMR?
I will be sending you pre-payment via mail.
Regards,
Mark
you might want to option for I got your order, Thanks!Driver Option 1 w/3800 ma upgrade.
P-7 Emitter
Tailcap - no glow, Black
Batteries and Charger
Trustfire TR-001 Charger
Trustfire 2500mA PRotected 18650 set of 2
Base Price $120.00
Driver Upgrade $25.00
Charger $10.00
Batteries $10.00
4% paypal $7
Total $172.00
Paypal is sent. I can't PM on this forum yet, so PM me for shipping info, (or it should be included on the paypal under "cnstman" Aaron, username)
Thanks!!![]()
Hi,
Am I correct that option 1 with the PC LED and option 3 are going to have the same max output of 1000 lumens?
Yes, they are about the same.
Is the main benefit to going with option 1 that there are modes and you can have the tail cap LED thing?
Yes :wave:
http://www.cpfmarketplace.com/mp/showthread.php?t=184887
Am I too late to order?
