Kremer
I'd like a 300mA version please.
(Unique Transaction ID #1RD81157Y0076461D)
Just for kicks I read the Maxim datasheet on the IC. I don't know how you have the indicator LED powered but it looks like you could make a double ended charger, maybe two of those USB connectors soldered or glued back to back and flipped so you get a little brick with a USB connector on each end, one side feeding the 100mA input and the other the 300mA.
Regards,
~Dougk
(Unique Transaction ID #1RD81157Y0076461D)Just for kicks I read the Maxim datasheet on the IC. I don't know how you have the indicator LED powered but it looks like you could make a double ended charger, maybe two of those USB connectors soldered or glued back to back and flipped so you get a little brick with a USB connector on each end, one side feeding the 100mA input and the other the 300mA.
Regards,
~Dougk
