BVH
JTS, I started and have continued to charge both cells at 1.0 Amp. I discharge them at 2.0 Amps. I have been charging to 4.1 V and discharging to 2.9 V. My Voltmeter agrees (within .02 Volts) with the Voltage display on my Schulze 10-36.12 charger/discharger. My connections are direct to the battery (no holders) thru very strong magnets and alligator clips. Voltage on both the clips and the battery ends themselves are the same so no obvious Voltage drop. Both batteries are stone cold when charging.
I just suddenly realized that both times I've seen over 2700 mah put into the cell, it's been on my 2nd channel of the charger. Not sure why this is when both channels are programmed identically.
I'll try a few charges to 4.2 and discharges to 2.5 as suggested.
