I wanted an easier SatCure circuit that someone could build without doing knat surgery.
Hosfelt has dirt cheap "FP" cores and 2N3904 transistors.
I tried 1, then 2, then 3 cores to see how closely I could get to the original circuit. I used a high efficiency transistor as well for the "standard".
What I came up with was 2 of the cheap FP ( this is the part number) cores will give you the greatest efficiency very close to the original and only a little larger. The overall current consumption was almost the same for all 3 BUT by using 2, you could get greater current through the LS. ( Saturation??)
Using 2 cores and 20-25 windings, I am running this at overall 2.72 ma and 1ma through the amber LS.
The wire I used is just a hair under the thickness of an index card...MUCH MUCH easier to work with.
I do not have a way to measure output SO I used a comparative method.
I used a Pal Gold as standard, index cards as the measure.
This "sat cure" circuit, drawing overall 2.72ma on ONE C CELL, will "punch through 5 index cards.
A pal gold on low will punch through 5.5.
It is a fairly bright night light drawing zip for power.
This was using a 47K resistor.
