corneileous
Well, I can't find the 20-watt incandescent bulb but I did find these, which is what I'd rather have anyways.... one is a spot beam and the other is a flood beam. Even though the flood beam is quite a bit more expensive, I'm still leaning more towards that one either way because it's got a higher lumen but I guess I could probably be happy with the spot version if I knew just how pinpointed the beam is.
I say that because a decade ago when I had the old halogen version of the Maglite MagCharger flashlight, I had found a LED upgrade online for that flashlight that I believe was made by Terralux? I think? It wasn't cheap but it was bright and I guess because since it took away the ability to change between spot and flood, the focusing of the beam pattern was fixed at like, half way between spot and flood. Kinda liked how it was.
But anywho, the flood lamp kit says it will work with the LiteBox lantern models with black handle powered by a sealed lead acid battery. Not exactly sure why the spot LED kit doesn't have that disclaimer but both kits should work, shouldn't they?.
Streamlight E-Spot Upgrade Kit 45845 | Streamlight Distributor
The Streamlight E-Spot® Upgrade Kit allows you to upgrade your halogen LiteBox® to LED. The Streamlight E-Spot Upgrade Kit has 3 bright white LEDs with 540 lumens in high (1,539 foot beam range) and runs for 7 hours. For an extended runtime of up to 15 hours, just change the brightness level to...
brightguy.com
Streamlight Litebox E-Flood LED Upgrade kit 45842
Streamlight E-Flood Upgrade Kit has six bright white LEDs with 615 lumens in high and runs for 8 hours. For an extended runtime of up to 18 hours, just change the brightness level to low with 330 lumens. Streamlight E-Flood Upgrade Kit gives a broad "flood" lighting pattern.
brightguy.com
