kosPap
Greetings all!
I have 2 questions that bug me about batteries for Handheld radios.
I have both options for my handheld Kenwood (TH-F7). The Sealed Lead-Acid is wired to the carcharger with a suitable female plug, and I can wire a 4D size case to the radio's 4AA battery pack with dummy cells.
So both options are workable. But I would like to know the differences,
One is mAh....Lead-Acid is 7Ah but the 4D-size is about 25.000 mAh and does't that make 25Ah? So will I be getting a longer runtime with the D-cells? Why do not I believe I will?
One more issue is Amp Draw. My radio drops its output automatically at 0.5W when the 4AA pack is used instead of the Li-Ion rechargable battery. Is there a reason that D size Alkalines can stand to the necessary draw for 5 Watts ?
On the other hand, using the lead acid batt is just the same as plugin in the radio in the carjack...but this batt is not fielf replendishable/replacable...
Glad to draw from your experience, kostas
