That's definitely a monster! I can't wait to see it in action. Are you building some sort of housing, or will it be an open frame like the Gorilla?
I will be bringing the 6.5 kW for the Deathray. It has a 30-Amp. 4 wire twist lock. It would be awesome if all
the lights could be up and running, so if you score a second 3K genny that would be awesome!
Otherwise, you can jack into my rig.
If you're going with the parallel 3K, don't forget to bring the magic Honda paralleling cable!
electromage said:Re: Seattle Area Get Together May 2014 or June 2014
That's definitely a monster! I can't wait to see it in action. Are you building some sort of housing, or will it be an open frame like the Gorilla?For the show I'm probably going to still have it at the Gorilla stage,
but plan to 'house it' like the commercial version of the NightHawk I sent off to New York.
For salable item, searchlight may just be one piece reflector, I don't know yet. Depends on demand. I'm going to experiment with different front lenses, (glass or plexiglass) I have a special cooling system which allows the front of the searchlight to only get to about 110 degrees Fahrenheit. I'll have sensors throughout to deactivate searchlight if proper cooling isn't assured.
I should have a little more than this at get together. i still have to wire up the ballast and make sure the thing even works. I don't like my jury rigging the ignitor, as finding the proper one without having to buy 200 or an entire searchlight is becoming a hassle, so I will use either my Tesla coil or oil furnace ignition Tesla coil with spark gap.![]()
Wow, that's a mighty big reflector.
It looks like I"ll make it up. Any updates on details?
I don't know anything about the schedule, I'm aiming for an early arrival to spend a couple hours assembling and test focusing the light. May be able to do it in the daytime up to several hundred feet, fine tune the focus after nightfall. :huh:oo:
:duh2: :ironic:
:devil:
:candle::twothumbs
I can bring my handheld lux meter and stand downrange with a radio to help you get it dialed in.
let me be clear. i do only have one of these eu3000is. it supplies 120V at 30A through a locking plug. otherwise you can go with the standard plug at 20A. i do not have another generator, and if someone else has an exact copy, and paralleling cables, i'd be happy to run parallel. but it's still only at 120V. if someone has something bigger, great.
hopefully that came through right this time.
Please do not try to paste in HTML formatted documents.![]()
And be turned into a smoking pile of ash?
PeeweeRe: Seattle Area Get Together May 2014 or June 2014
not sure if it would be any use, but i do have a 2500w square wave 120v inverter in my jeep, id say probably shouldn't draw anymore than 30A through it though.Bring it just in case. Sometimes igNITEor and I have gotten creative...we may be able to do something with this to solve some unforeseen issue..
This is going to be epic.
Here is just a 60 watt test bulb for preliminary focus and alignment.
60 watt incandescent bulb = 15 watt CFL 600 lumen. Searchlight will have 380,000 bulb in a couple weeks. Makes four focused spots on a tree 150 feet away. Will converge them into one soon.
Preliminary focusing uses low wattage bulbs so I don't scare my neighbors too bad. 380,000 lumen bulb will go in soon to replace 600 lumen bulb now in use. Will be 633 times brighter.
Four separate spots will be converged into one soon.
So spreading the word....
I Posted on WaGuns www.WaGuns.org http://vps.rmcgirr83.org/~waguns/search.php?search_id=newposts&sid=4a4b2b43583a4fbb3c81db450d3ccd23
and SGN Seattle Guns http://seattleguns.net/showthread.p...nton-on-Sat-June-7-2014&p=1279772#post1279772
If I can make it I'll see. I don't have my work schedule for June yet.
I did include a suggestion to those attending from WaGuns and SGN to bring food to share (potluck) and not to remove firearms from holsters (since these are firearm sites).
