Sold/Expired Sell:custom Quad XP-G P60 module 3rd Run *open*
kerberos0023
Tokyo Japan
:welcome: I sell this!
The 3rd run will be limited to Direct Drive 4200mA 3-mode XP-G R5 only! The sale number is ten in all.
The module sends it out from the middle of January, 2011.
I begin to sell it for $160(Direct Drive) $180(4200mA 3-mode) including the EMS postage!
The GITD processing is plus $10.
This becomes very hot.
The use battery is with 3.7V Li-Io battery protection circuit.
If a light becomes hot, please cut the light which is in a dangerous state.
Please be careful to the handling.
After understanding, please refer as things mentioned above.
?This light creates excessive heat :caution:
?The consecutive lighting is dangerous. :caution:
?If a light is overheated, please turn off the light.:caution:
?This light may cause eye damage :caution:
?This light will burn the skin at close range. :caution:
?This light may cause combustibles to ignite :caution:
?This drop-in is a direct drive unit. :caution:
?IMR cells are not recommended. :caution:
When you used the large-capacity battery except 17670 and 18650 of the battery with the protection circuit, the possibility that an excessive electric current flows, and LED is broken is very high.
Because I sell 4200mA converter in 2nd Run if you use a large-capacity battery except 17670 and 18650, please wait till then.
Please use only 17670 or 18650.
It is very likely that LED is broken! :caution:
:thumbsup:
I sell this custom Quad XP-G P60 module.
I begin to sell it for $160(DD) $180(4200mA 3-mode) including the EMS postage!
This light creates excessive heat.
Please use 18650 or 17670 expensive battery of the electric discharge performance.
The payment is PeyPal.
Post your order here and I will PM you the total along with my PayPal address.
Cutter-XPG25RDR5-CW (remodeling board 20mm)
Carclo 24mm Quad Optics
Quad XP-G DD Module
Quad XP-G Module 4200mA 3-mode
*3 modes: Low-Med-High
* Voltage input: 2.8V - 5.5V
* The memory feature will memorize the last mode
surefire 6P C2 normal body
:thumbsup:
Quad XP-G DD Module
Keshi,
I found your "open" thread selling the triple XP-G for the Solarforce L2P. However while I found it doing a search I the site does not allow for threads that have been added to. So I decided to try to contact you using this thread in hopes that I can purchase the module drop in that I want.
So, if the administrators allow my first post to go through in the thread that I found doing a search you may see this same request from me. The part I want to buy is listed here below. I don't know if the part includes heat sink and Carcla lens. I wish to buy the part in any event. My email is [email protected] Please contact me there. I can make Paypal payment if you can sell me the part. Also feel free to let me know if the cost is higher now.
Thank you
Jim
4) tliple XP-G R5 3-mode 2800mA $135 Mat black 😀 G.I.T.D 😀 A part of the PCB In stock : 1
