Sold/Expired Sell:custom triple XP-G P60 module for surefire 6P
kerberos0023
Tokyo Japan
Sell:custom triple XP-G P60 module for surefire 6P *close*
:welcome: I sell this!
I begin to sell it for $130 including the EMS postage!
Cutter-XPGMR8IAD
Carclo 20mm Triple Optics(Narrow lens front)
heat sink (Aluminum & brass)
2800mA AMC7135 *8 LED driver (3-mode:Low-Med-High)
triple XP-G P60 module for surefire 6P.
Package included : triple XP-G unit & Carclo 20mm Triple Optics(Narrow lens front) & One O-ring
This module is not HA processing.
It is the graphite painting.
The graphite painting is waterproofing having strong coherency, oil-resistant, heat-resistant superior graphite spray.
Iron, cast iron, copper, copper compound metal, aluminum, stainless steel come by graphite coating to every metal.
http://www.tobika.co.jp/products/index.html
The converter is an AMC7135 *8,3-mode.
From article explanation of ShiningBeam.com,
* Regulated circuit board designed for Cree MC-E, SSC P7 and SST-50
* 3 modes: LowMedHigh
* Voltage input: 2.8V - 5.5V
* The memory feature will memorize the last mode
* Output current: 140mA on low, 1,000mA on med, and 2,800mA on high
* 17mm base board diameter
* Lead wires already soldered on the board
* Reverse-polarity protection prevents wrongly installed batteries from damaging the circuit
It is non-measurement for the run time with the high mode.
I drove it with a high mode consecutively.
It is temperature of the body warmth rank in five minutes.
Is hot in 10 minutes; feel it.
Because I was hot, more than this turned off the light.
:thumbsup:
I sell this custom triple XP-G module.
For surefire 6p.
I begin to sell it for $130 including the EMS postage.
This light creates excessive heat.
Please use 17670 expensive battery of the electric discharge performance.
As for this module, a plus pole is a short spring.
On this account this module is uncongenial to a Z41 tail switch.
I recommend a Z59 tail switch or use of OVEREADY McClicky Kit!
Please choose R4 or R5.
The payment is PeyPal.
Post your order here and I will PM you the total along with my PayPal address.
Mat black
It is unified by the following thread.
http://www.candlepowerforums.com/vb/showthread.php?t=277951
Hi Kerberos
what do you figure the output on medium is at 1A for the R5s and will that level run continuously even if the light is tailstanding or will thermal shutdown to protect the leds occure after a period of time also?
Thanx for your time !!
Hi Kerberos
Hi purelite,
If it is a low mode and a mid mode, consecutive lighting is possible.
Thanks,
Kenji :wave:
Hello. Are you going to have any more of the R4 triple for surefire 6p? I know you have one made for the solarforce l2p but will this 6p version work in the l2p also?
Hi,
Probably I think that I can use it.
However, the diameter of the 6P module has a smaller 0.2mm than a L2P module.
Thanks,
Ok. I would like to buy a triple XP-G R4 (warm) 3-mode 2800mA $130 Mat black. Do you have any in stock or are they sold out?
I just wanted to come by and say how much I love this drop-in. Yes, it's expensive, but the construction is very nice and my lord it is bright.
I do have a question though.... Will it be even brighter using an IMR 18650? Currently I'm using a Trustfire True 2400 (the black one with the flames). If the difference is only a little bit, I won't bother because of the decreased runtime, but if it's going to be even brighter then I might be tempted to try it :)
Hi adept1, :wave:
I recommend it.
High ability for electric discharge and 18650 big batteries of the capacity are good.
The low battery of the ability is the output equal to or less than 2,800mA. Therefore, it will become lighter if I use a good battery!
Thanks,
Kenji
Can these modules be used with primaries? What is the input voltage range?
I suspect that not even a single primary can be used on this as the output current draw is 140mA on low, 1,000mA on med, and 2,800mA on high. But since the input voltage is 2.8-5.5V, it could be used with a RCR123 or IMR16340 with a dummy CR123 cell. Because one may not own a 17670 set-up. Correct me if I am wrong.
