Seoul P4 Custom MagLite *CLOSED*
Nitroz
Monroe
Re: Seoul P4 Custom MagLite
fleegs said:
Does this flashlight have water resistance? Can I drop it in a puddle without any fear?
rob
IMO, it needs water resistance from the drool. :drool: :laughing:
Cmac,
That is one awesome light! I have a P4 on the way for my cutdown 2c with flupic. I hope mine is a bright as yours.
XFlash
Oklahoma
Hi Mac,
I'll take 1ea Silver -Style 1 powered via a single 18650 cell and will include a PVC sleeve to center the cell. 175.00
with all the below
-Finned Head $20
-Fluted Head $30
-Grooved Body $15
Total - 240.00
Are style 1 and option 1 the same in the discription, just want to be sure about the runtime.
Thanks for the great work.
cmacclel
Sweden
rob
Should'nt be a problem if you dropped it in a puddle.
Mac
cmacclel
Sweden
Sorry for the confusion I updated the first post. Option 1 = Style 1, Option 2 = Style 2.
Mac
jch79
**Do Not Feed The Vegan**,
On the asphalt.
Hey Mac,
Is this sucker focusable, or fixed?
I haven't followed Mag modding too much, and don't know what the standard is for these types of mods. Thanks!
:) john
philw3
Delaware
doesn't 3 x 17670 = 3 x 3.7v ? I thought the flupic is only rated for 6v max?
Very nice work Mac
Phil
cmacclel
Sweden
Very nice work Mac
Phil
The holder is parallel.
Mac
dksd39
South Florida
WOW-- very nice. Too bad I already spent my flashlight money for next month--
jch79
On the asphalt.
jch79 said:
Hey Mac,
:) john
Was my question that dumb? :(
cmacclel
Sweden
Sorry I missed your question, and no it's not dumb :) The light is fully focusable but I never understood why you would unfocus the beam. In every flashlight I have seen there is only one sweet spot where the beam is optimally focused.
Mac
mcmc
cmac, any chance that an option 2 that's not tri-bored for the 3 17670's would be able to run off a li-ion D?
cmacclel
Sweden
That should'nt be a problem. You could just order an option 1 then when and if the "D" Li-Ions arrive you could just knock out the spacer sleeve.
Mac
mcmc
Got it. Cool, thanks! =)
Btw, is the one in the pics pewter, or silver?
cmacclel
Sweden
KDOG3 said:
That is a metal reflector right?
A metal reflector is not required for LED use. Also the stock smooth reflector in my experience is better than the aftermarket carley smooth reflectors. Metal reflectors are only required in high heat applications.
Mac
LuxLuthor
MS
Mac, I just got one of those Meterman 631's and am amazed at how easy it is to peg out the 20,000 Lux with all of my Maglite hotwires, depending on a slight adjustment in distance (ideally a perfect 1 meter), and getting the hotspot on the sensor.
I'm just wondering how your reading was standardized and how it compares to say some SF lights like the L2, M4, M6. I'm still very inexperienced with appreciating this LED area.
cmacclel
Sweden
Lux these light meters like the popular LM631 where purchased to measure led lights. High power hotwire are in another class all together. In order to measure higher power lights you need to move back to 3 meters then times the output by 4 I believe.
The L2 only outputs around 2000 lux on high but this only means it not a "thrower" it still outputs 100+ lumens. When measurling lux your only really measuring throw.
I don't know about the M4 but the M6 will max the meter out at 1 meter.
Mac
ryball
:grin2:I want one. :eek: I best stop buying other things so I can save up for this.
