vacuum3d
I noticed that the Shoppe has these copper discs (0.03") designed to raise the P4 by 0.30". Does it mean that the reflectors need to have the same amount of material removed? Anyone?
Thanks,
ernest
Thanks,
ernest
McGizmo said:The P4 will work with the relectors designed for the Luxeon LED's. To get a good focus, the P4 needs to advance forward into the reflector by about .030" or there abouts. With the McR-27, 38 and 45, this can be accomplished by letting the reflector overlap the LED. With the McR-20 family which seats against the LED, you need to remove material from the rear of the reflector. I know I have made these comments a couple times elsewhere but the joy of CPF is the opportunity to repeat oneself again and again until your wind is all gone! :nana:
