Seoul Semiconductor launches Ultra-Slim Z-Power LED Z1
Re: Seoul Semiconductor Launch Ultra-Slim Z-Power LED Z1
Is this new?
Maximum lumens of warm white NZ10150 and pure white WZ10150 are 95 and 120 respectively, the average lumens being 80 and 105 each.
http://www.led-professional.com/content/view/1191/29/
How do you focus it? It looks flat and has no primay optic.
They really do not provide enough info with that release.:shakehead Thats SSC for you. It would be no different than any other LED as far as collimating the light. It does not need an optic as part of the package to accomplish this.
That's a high VF with a nominal of 4.1v
120 degree emitting angle.
Pretty high C/W.
This was designed for fixed lighting. It obfuscates the die, doesn't have a dome to help with collimation, and is rectangular and low-profile.
Don't see why you say it was designed for fixed lighting. Here is what SSC say it is designed for. "Z-Power series is designed for high
current operation and high flux output
applications."
"•Mobile phone flash•Automotive interior/ exterior lighting•Automotive signal lighting•Automotive forward lighting•General Torch•Architectural lighting•LCD TV / Monitor Backlight•Projector light source•Traffic signals•Task lighting•Decorative / Pathway lighting•Remote / Solar powered lighting•Household appliances"
It obfuscates the die, ...
I think there has been enough obfuscation already Luke. No need to add to it.:poke::D
From the datasheet, it looks like there are 8 small dies connected in parallel, so not a 1mm2 die. Could be the reason for the relative high Vf.
space
space
Yep. And why it will be better for fixed (flood) lighting than it will be for flashlights.
