larryk,
It could be done, and is something I've thought about--I even got a burnt out SF lamp from Britt for free for this purpose--but there are two problems, or actually three for most people:
1. You need a good ceramic potting compound, such as the Cotronics 940 LE.
2. You need to get the filament not only centered, but also at the right height, because there is no room for focusing adjustment; the collar hits the back of the reflector and wherever that filament is, that's where it will stay. With the ring-potted lamps I make, you get to move them in and out and then tighten a set screw. Not so with the double spring SF LA's.
3. The leads from the lamp must be quite long--longer than they are--in order to be soldered to the appropriate places on the double coil springs of the LA. You could run jumper wires, but I'm pretty sure that the ends of the lamp leads on an 1185 get way too hot for even the higher temp solders. You could braze some jumper wires on, I suppose.
Anyway, it's an idea with potential, but it's certainly going to be labor intensive and difficult.
