Just after thoughts, still waiting on my R2 drop-in from DX for my Hugsby M2. But have been rading and thinking more about better quality and also seems it's not so easy to get some accessories to fit correctly with these Surefire knock-offs.
So I was thinking of working along the lines of a 6P but then noticed that the G2's are quite a bit cheaper. Whats your thoughts on these and would they be just as good as a 6P. Is the only difference the material they are both made of ? Again it's main pupose will be rifle-mounted with a red-filter for 30-50meter use (most is under 40meters).
Or the next question is, can you think of a better thrower/tight beam flashlight that has the same size body (needs to be for the rifle mount to fit). Again, still want a red filter, and would be great if I can use the rechargeable 123A 3.7v batteries I already have.
