SF KL1 is now available in Germany
Nerd
Singapore
I'm telling ya the KL1 or any other good LS based lights are a must gets. Only when you saw it will you feel how great it is to be able to have the colour white.
Artar:
Yes, but a slightly blue white. I am sure the KL-1 is a much higher Kelvin temperature then the MN-03 lamp.
I have two KL-1's. The first one is slightly brighter then the second. Both to me, are very useful lights. In fact I replaced the bezel on my E2e EDC with a KL-1 and use it every day.
The KL-1 has cut my 123 lithium battery usage quite a bit.
You know I would not tell you not to get one would I?
www.ph-import.com sells the KL1 for 55€.
i cant decide if i should get one or not
i have 2 SF E2 HA III and one of them is always with me. i also have always a photon II and arc aaa on me.
Why should i get an led head for my E2 ?
a) becaue of the longer runtime ?
b) because the led(-bulb) will never burn out and i will have always light
c) because i can run it with my half-dead cr123's
d) because its so cool
my answers to the questions above :
to a)
no, i newer used the E2 longer then 5 minutes constant on, and if i need longer runtime than 60 minutes i use my arc aaa
to b)
yes and no. the led-(bulb) will last longer but the xenon bulbs is much brighter and has more throw.
to c) ok, thats right. but i can keep the half deads 5-10 years and wait for a regulated xenon flashlight
to d)
yes, its cool, but the very bright white light of the mn03 is also cool.
what would you do ?
