W
Wayward
Shortly after I recieved my second U2, I noticed that it had two distinct scratches on the reflector as well as a fairly blue tint. I called Surefire, told them that I needed an RMA number, and shipped it off. Today my U2 arrived back home after approximately two months. The tint is the most neutral of the the 4 SF LED's I have, and the beam is doughnut hole free.
This is what was listed on the invoice:
ITEM NO. 15861-1: BEZEL ASSY, GRAY NL, WHITE LED
ITEM NO. 60-30-001: 3V LITHIUM BATTERY, SF123A
Although it took 2 months, I have to give SF a big thumbs up !
P.S. I've noticed something different between the repaired U2 and my other one. My original U2, and I believe my repaired one before it went to SF, when on brightness settings higher than level one, will start out at the low setting for a brief moment before jumping to the set brightness level. With the newly repaired U2 there is no delay; it's instant on at any level. Has anyone else noticed this? Has there been a change in the U2 electronics? Thanks.
