Shiny Chrome To Hard (Dull Chrome)
skalomax
Southern California
Hi, In route Is a special light that Is all Chrome (Shiny).
I was wondering If it was possible to convert It to Dull Chrome for a more durable finish.
Like this
Thanks, Also who Is capable of doing such feat?
(Photo by ErinO919
I'm not sure how a chroming process works but I think a matte finish might be possible on a heavily knurled surface:candle:
if you wanted dull chrome you might as well go for anodizing for durability
Just set up my beadblast cabinet over the weekend.
Doing some blasting on an aluminum engine intake and there was a hi gloss crome water inlet with some damage. Just to see what would happen I blasted half of it. It came out very nice, smooth even finish with no signs of having gone compleatly through the crome. This was with glass bead media at 80psi. I would suggest starting at 30psi. Most other blast media's would be far too agressive. IMHO
Leadfoot
Thanks for the info guys.
But do you think It's possible?
The "shiny" chrome looks great, but I would like something more durable.
shiny chrome and matte hard chrome are vastly different coatings.
as the name implies, hard chrome is a durable finish, where as shiny chrome is more cosmetic. consult your local plating and finishing shop. they may be able to do a small piece for you cheaper than you think.
Having had a number of handguns hard chromed I can say from experience that it is very rare to find a shop that will hard chrome aluminum. At best electrolyess nickel is doable in a matte finish, otherwise anodizing is the usual treatment. Decorative chrome is a surface plating and cannot be converted to a durable matte finish.
It is my understanding that the item needs to be highly polished before the chroming process, in order for it to come out shiny (like a mirror). This was told to me by Fivemega (who, as you know, does a lot of chroming). Hearing this made sense to me, too, because when I was younger,I had a bicycle chromed and the insides of the split frame were not shiny and I was told that they couldn't get the polisher between the two parts of the frame (it was a Jimmy Wynert (Winert?), later bought by the Torker company. If you've seen a Torker, you know what I mean by the split frame (split top bar...actually, there are other brands of bikes that have had this design, but they are mostly ten-speeds)
So, maybe, if an item is stripped, but not polished, the chroming process will leave it with a dull finish. Nothing solid here, just what I think. I may be right, I may be wrong, but either way, I'd like to know the truth and see some examples of a non polished piece being chromed.
