Shootout AW vs. Redilast 18650 2900mAh
LuxLuthor
MS
I bought batteries from both vendors at my own expense (no shilling or favoritism or promotion should be inferred), and wanted to compare them. They are obviously both using the same Panasonic NCR18650 described in this PDF.
The Redilast cell had the label removed by CPF member csshih in this thread, and I was willing to do the same with one of my AW cells, but given the nearly identical discharge curves and claims by AW, I saw little point in taking one of his apart.
There are a few things to consider in examining these two cells which are closely priced. I charged 2 of each brand in two Pila IBC chargers, figuring it would be the way most of us would charge. I waited until Pila turned green, took cells out, waited 30 mins, then reversed cells in chargers in case one charged a bit higher. Removed re-charged cells when light turned green, and let sit for an hour for charge to stabilize.
I used my Fluke 189 to set the voltage calibration values in my CBA-II Pro software for each discharge rate, and confirmed there was voltage correlation during the run at several points, which was recently discussed in this thread.
1) Interestingly, the cells ended charging with slight differences determined by my Fluke 189
AW #1 - 4.188 V
AW #2 - 4.192 V
Readi #1 - 4.206 V
Readi #2 - 4.198 V
2) I don't feel that these cells hold their voltage very well under any kind of a medium load. So you either need to use them in low amp demand applications, use multiple cells to get your delivered voltage under load into the range you need--and then likely use regulation, or settle for a better performing cell under load.
3) At the 5 amp discharge the cells got warm to hot. Best I could measure with Fluke temp probe, and another Laser thermometer, and by touch, I estimate they get up to about 115°F (46°C).
4) The AW cells do not seem to finish the last 100-200mAh as well as the Redi, but it is pretty negligible at that low of voltage anyway. Still, I have to give props to Redi.
5) I did not see the PCB low voltage protection cutoff at 2.5V with the AW cells which concerns me. For the 2A test, I set the endpoint at 2.4V, and the AW's PCB did not terminate. I dropped it to 2.3V cutoff for the 5A test, and it still did not terminate. I ran another test not shown after a partial charge, and found that it terminates at 2.2V which is probably a bit too low if using a low amp draining application. So I have to give a nod to Redilast on this point. The Redi #1 cutoff at 2.42V, and #2 cutoff at 2.33V (I watched the dropping voltage number display box)
6) After the cells reached their endpoints, their voltage rebounded back up to at least 3.25V within 2 minutes. Damage to Lithium Cobalt cells is correlated to how long they spend under 2.5 to 2.7V, so I'm not concerned that even dipping this low is an issue.
Looks like we have another reputable 18650 supplier (about time!).
Good job Lux, I gather you meant to say swapped. :wave:
Norm
Yeah, did the old change-a-roo to make sure there wasn't a preferential charge termination between the two Pila IBC's that might have put more juice in one set of cells.
Norm
Yeah, if you read that with half an eye it almost looks like you put the cells in backwards for some strange reason ;) But i get what you mean.
Nice little head-up on the Redilasts btw :thumbsup:
I expected that... I like multiple cells to get to 2-5A, which is enormous load IMO.
Just got a few Redi 2900s and it's too long to fit Zebralight. AW2900 was reported working fine with ZL.
Which model Zebra Light the SC60 or the SC60W? LuxLuthor thanks for taking time to run this test. I have the Redi 2900s but not the AWs and was wondering if there was much difference.
Good job, Lux. I've been thinking about and observing high cap vs. drain rate for some time. It appears that Li-Ion cells and thier cousins, NiMH, have similar characteristics in this regard. Compromise, appears to be a necessity when constructing high cap cells of either chemistry, in order to achieve higher capacity.
Dave
Staying with the theme, other compromises to wonder about would include durability and longevity... :thinking:
I would consider dimension as one of the factors to be considered. You won't compare 18650 vs 17670, would you? If one's dimension is on margin of spec and when 2 of them are used, it might cause problem. Please note that not that I am saying one is off spec as none does (most 18650 are 670 or 680).
Alan
I don't really think you can consider the dimension of the cells. There are no "standard" dimensions for individual, or "loose" protected Li-Ion cells, as no manufacturers make any. The added length of protected cells is merely an inconvenient byproduct of third parties adding PCBs.
Dave
Dave
The standard is 65mm +/- 0.2mm for industrial 18650 cell. Battery sellers add their own protection circuit that add more height. Most add up 2 mm +/- a few percent but some add more than 3 mm.
Redi Cells measured 68.7 to 68.9mm and I got 4 of them. I'm not sure it's their typical length. Lux might want to chime in the dimension of AW2900.
For ZL SC60, you could use Panasonic NCR18650. SC60 (not H60) has built-in cutoff feature at 2.7v. Although SC60 will protect the cell from over-discharge, it won't protect it from being over-charged. It means you might want a good charger like Pila.
18.25 x 68.04 mm (outside of 3 contact points of neg end) Widest is over the protection strip running length.
My apologies. I didn't word my post very well. What I was pointing out, is that there is no standard dimension for "protected" Li-Ion cells. The dimension of "protected" cells depends on what PCB Redilast or AW, for example, add to the manufacturer's cell. Of course, this is a consideration when choosing a cell for a specific application, but has little to do with standard cell sizes. So, when you compare "protected" 18650 and 17670 cells, they likely are not actually that size, as there is no standard dimension for "protected" cells.
Dave
Thanks for doing this. I have so many lights that will not work with flat tops. Every thread I've seen on the Redilast so far is positive. I think I will have to order a few of the 2900.
