Should I????
cmacclel
Sweden
Buy it?? I guess it runs good and most of it's life cut plastics. The tooling it comes with it worth the $2500 asking price.
Wells Index builds a high quality machine, every bit the equal to a Bridgeport. Problem with a Bridgeport is the name ... everybody knows that name & wants one of those. Fewer people are familiar with Wells Index.
Nice people to talk with on the phone, and they offer spindle regrinds & rebuilds at very good prices (if you ever need that). Tooling looks like Kwik Switch, which you will love😀
http://www.wellsindex.com/
If it's a lightly used machine, it's worth $2500 with no tooling.
If you decide to pass, please forward me the information. This is the machine I am looking for.
Thanks,
Ryan
Quick Switch 200 he said he has tons of tooling including a tapping head. I'm going to look at it tomorrow. It needs to be gone by Friday.
Mac
if the control is too old you may want to replace it with mach3 and maybe keep the servos or steppers
Pablo
That would probably cost the same price of the Mill now with alot of work....right?
Mac
As someone once said about mills used in plastic - often the spindle bearings are shot, and ways word due to the very high speeds used. Just double check
Mac
Depending on what you need to replace, if the machine is CNC you already have the ballscrews in all the axis, you should check if they are in good shape, then you need to check if the servos or steppers are also in good shape, then check if the motor drives are too old or would be better to upgrade to something more modern, these run less than 150 per axis, check www.geckodrive.com, then you need a $300 PC and a Mach3 Licence ($175) You make your $$$ figure for elbow grease and time.
CNCZone is a great place to ask/learn, the process of replacing the whole control box and/or motors its called retrofitting.
Lot of work? probably, lot frustrations? depending on your planning, lot of learning? thats 100% guaranteed, fun? for sure too!
Pablo
Do you have room in your shop?
Nope not unless I get ride of my 3in 1 and mill but still am not sure if my ceiling is 92" tall. I just looked at the machine and it is fully functional. My decision will be made today the only part I see being an issue is getting it off the trailer into my garage. I would need to remove the motor to get it through the garage door for sure. Getting it off the trailer is where I'm worried, I do not want to hire a rigger.
Mac
Mac,
It will inside your garage perfectly fine.
However, it will not fit your "mini-shop". You'll need to remove the head assembly from the knee to get it in there piecemeal.
At the price of $2500, if the ways are decent then it's definitely worth the price.
I'm assuming that it have ball screws.
Here's the breakdown Mach3 upgrade cost depending on your needs.
Geckodrive G320 Servo Motor Driver ... $110/axis
NEMA 34 1125 oz-in Peak Servo Motor ... $149/axis
DC Power Supply ... $149
Parallel Port Breakout Board ... $80
PC ... FREE (I know you're upgrading every year so you bound to have one or two extra).
Mach3 Licence ... Free for first 1000 lines after that you need $159 licence.
Heck that machine as is if the ballscrew is good your 90% home free. Most of the work is the coupling and gearing solution from the servo to the ballscrew drive.
GET IT! And you'll be 100% CNC in your shop.
But you know those Yaskawa & Sanyo Denki that you have are FAR more superior 😀
http://www.kelinginc.net/CNC34ServoMotorPackage.html
Mach 3 licence is free for the 1st 500 lines of code, I know I'm a reseller 😀
For user generated code, 500 lines is usually more than enough, for CAM generated code its not near enough.
From their site www.machsupport.com
Mach3 is the flagship of the ArtSoft products. It is released in two versions: a Lockdown version, and a Development version. The Lockdown is a stable, static release recommended for new users, or people trialing the software. The Development version contains developing features and is released quite often so people can obtain new (but untested) features and capabilities. Both releases are limited to 500 lines of Gcode until licensed
I agree with Jonathan, if the ballscrews / ways are OK after a retrofit you will end with a very nice machine.
Pablo
When you pick it up, before loading onto your trailer, bolt a 2x12 under the front & under the back of the base, with the lumber running parallel to the table long dimension. Stop by a hardware store that cuts black iron pipe, and have them cut half a dozen 1" pipes, about 6" longer than the front to back distance of the 2x12's. To unload, use a pair of long pry bars to lift the end of the 2x12's enough to get the first roller under the boards. Move it forward 6" and insert another pipe, etc. You'll need a cable hoist or pulley system to control speed on the ramp.
A couple of friends really helps 😀
I followed the same advice Barry gave me several months ago and that is exactly how I got my knee mill into my garage 😉
Will
Well I called my rigger and he said $500.....I then offered $2k for the mill and he accepted my offer this morning. The rigger is picking it up tomorrow 🙂
Now for the biggest learning curve yet!
Mac
Congrats Chris, I hope it works out well for you.
Now to punch out a wall it the workshop and raise the ceiling!:poke:
