Leeoniya
i've been doing some research on constant current and DC/DC converter step-up ICs.
my design specs required as low input voltage as possible, small surface mount package, high efficency - 90% or more, and reasonable current handling capacity...with enough overhead for small error to drive a lux 3
i came upon the LTC3426 and decided to see if i can find it anywhere on the CPF forums as being mentioned in a single cell or multi-cell design. the search yielded no matches over the past year. so i am now set on designing a drop in module based on this IC...it has the potential to be very small and very efficient since it's SOT-23!!! and has few components other than the inductor that need to be large...which is also relative.
datasheet
it will most likely be similar to a MadMax...i dont have a MM so i dont know what the MM design is. but i've never seen the use of an sot-23 IC in a drive application before so i think it would be intriguing to make one. and i have a feeling i can make it quite small.
maybe if there's enough interest i might make many and sell them for something reasonable. or i'd be happy to split the revenue with anyone who has good connections for mass producing surface mount stuff.
either way, i'll post schematics and a parts list.
i'll also try to make it the circuitry as tight as possibly to allow intyegration into the smallest diameters of flashlight, and try to make it very easy to swap out emitters...eg having the solder pads free of nearby components.
Leon.
datasheet
Leon.
