Show your D and C mag mods
just looked in by chance....those are Mcr27xr's cut down and a custom heatsink I made. I did it that way because I wanted to fill the head with reflector.
Thanks for the reply! It looks great with the 3 decent sized reflectors; I'm assuming you cut them down on both ends?
I'll have to take some pictures of the few Mag mods I've done and post them up... I'd forgotten about this thread until it was brought back up!
I only made one cut, the vertex opening is correct to fit the P7 in that reflector so I only cut the OD down...VERY VERY slowly I might add 🙂
I just measured for you, if you decide to replicate it...they are cut to .904. Then there is also another land on the back that I just touched off to clear the reflector in the mag head. You will see it if you do it.
here are a few pics on the heat sink as well if you want to use them
http://i212.photobucket.com/albums/cc294/andrewmettee/Mods/TripleP7003.jpg
http://i212.photobucket.com/albums/cc294/andrewmettee/Mods/TripleP7002.jpg
ElectronGuru: Those look amazing! I'd be very interested if you are planning to sell coated & bored C-cell Maglites.
Mettee: Thanks for the information! I'm assuming you did that work on a lathe? I really need to get myself one; even a mini hobby lathe would be great for a lot of light parts. :sssh:
From left to right:
  • 2 C bored with 2 IMR 26500's, Download's C heatsink, cren bezel, Litho MOP and 3854 H
  • 3 C bored with 3 IMR 26500's, KIU mod switch, 1185 and FM bi-focal
  • 2 D with FM 6aa holder w/6 Eneloops, KIU mod switch, Litho MOP and 5761
  • 3 D with 4 IMR 26500's, shortened and recessed tail spring, rocker mod switch, KD MOP and 64623
  • 4 D with 5 IMR 26500's, rocker mod switch, KD MOP and 64458
  • 6 D with 7 IMR 26500's, rocker switch mod, FM's FM3-X and 64656. More here.
  • 4 D cut and quad bored by FM, Download's Mag ring with skull lanyard made by J Smith with 16 Elite 1700 AA's, with rocker switch mod, FM Throwmaster and 64458
  • 3 D with FM 9aa holder, 9 Eneloop aa's, KIU mod switch, Litho LOP and 1185 and Nite Ize grip
  • 2 D with 3 IMR 26500's, shortened and recessed tail spring, KIU mod switch, Litho MOP and Hikari 5607
  • 2 D with FM 6aa holder, 6 Eneloop aa's, KIU mod switch, Litho MOP and 1111
  • 2 C with battery sleeve made by Darkzero, 2 AW 18650's, FM wide/deep tailcap, Download C heatsink, ModaMag MOP and 3854 L
latest update, some mags redone, some are new.
from left clockwise.
2d mag p7 5 mode(dx driver) 6AA in FM holder, FM deep led reflector.
2d mag tle300, 6x lithium's AA in FM holder, green flashcap.
4d dualbored, 6x18650 3s2p stock reflector switch, lens, uses dewalt 12v bulb, future project, that bulb is :thumbsdow
4,5d (3d +88mm extention) 3xp7 DW kit, 6 modes, 4x32650 cells protected, white flash cap.
4d FM par36 head, 4115 bulb, 6xsub c, white flashcap.
4d FM 2,5in throwmaster, aw soft start, 90w bulb, 4x26650 cells, resistance tailcap mode.
4c bored out mag 85, 3x26650, ntc tailcap mode, deep reflector by FM, boro lens.
4c rop h, FM bifocal reflector, 6x4\5 sub c, boro lens.
2c p7, 2x18650, 5 modes.
2aa mag with 3x5mm green drop in.
3aa stock lx100
I love the C Mag mods, I had to try out my new old lathe to do a few more.
The black one is a bored 1C 26650 powered P7 with a stripped polished tailcap and bezel. It's been dressed up with the lathe. It uses a 8X AMC7135 3 mode regulator and a stock sputtered reflector.
The silver is a 2C 2X 25500 with 4X Cree XP-G R5 and 4 Ledil reflectors mounted on a Download heatsink. It also used the 8X AMC7135 3 mode regulator wired with one of Download's specialties, the 3 wire. It was also dressed up with some grooves on the lathe.
Not overly modded. Still stock on the inside but I slapped some Grip tape, for ease of handling, on the outside. Also slapped a coat of krylon on it and stuck a SMG Magpul on the end with a D-carabiner. Ive two this way. One for my truck and the other house. Looking to at least get a couple LED Upgrade bulbs for them.
Cheers!
Cheers!
that looks too legit, nice work!
