Show your Rare/Unusual SureFires - Part 2
Status
Not open for further replies.
angelofwar
South Carolina
But of course I can, sir. Yes, they are made for ASP batons, I guess they will work with other brands too if they use the same thread size though.
Sweet Get-up! I'm looking to get a 3BL in a trade, but, man, that looks sweet! Just enough light for searching in the "ready strike" position!
Thanks for posting the pic!
angelofwar
South Carolina
This is not rare at all, it's one of the most common lights on CPF and it's not even discontinued.
But it is a bit unusual, as the laser engraving is totally off-center:
Looks like SF's machinists have been hitting the bottle again! LOL! Not as bad as my D3, but, man, that's pretty bad!
ficklampa
Stockholm, Sweden
Sweet! If you want more light than the R30 incan will give you can always get the D26-LED drop in from lumens factory. I just got mine and it is bright! Could be used also for blinding if needed. I will get probably a 6P-ish head, or maybe use my 6PLD head depending on prices and stuff. Will probably EDC it as a 3P LED just for fun. the 6PLD is a bit big sometimes. I'll see what I will do. Will probably not have it on the baton since it's pretty big with it attached, if I'm not leaving it for self defense at home though.
Solscud007
Brentwood, CA Not LA
Goes to show how infrequent I come here. Nice score Rat!!! I am jealous of the Hellfire. Now you need to get one of Macs handles. or if he ever sells the battery pack.
tobrien
Georgia Highway 441
so what's the story behind the Winelights? Was it just a borderline gimmicky promo? I think they look cool, I'm not dissing them. :)
I mean, they're standard models painted purple right?
Rat
Australia
The Hellfire ended up coming with the Surefire cable which I was not expecting. It was as new as the light and plugs into my trucks cig/lighter plug.
I do not plan on using this light much so I think the cable will do me for now.
But I sure do like the Macs handles but I do not think I will get the use out of it.
cheers
Ethen
China
My E1DL
Handmade sand color,Flame ignition processing.Fire after the BK into the sand color.
Size15's
Kettering, England
Just bought this light, but don't know the part number.
It's unusual for the L6x to be mounted on an A15 as this separates the batteries so this isn't a stock SureFire Classic WeaponLight as they were designed around the SFx23AC Shock Isolated Battery Sticks such as the three-DL123A containing SF323AC.
The components are:
- L6x Lamp Module. If it's a three-SF123A light it'll have the P90 Lamp Assembly making it the L69 Lamp Module. Note that I don't believe this is stock item.
- A15 Offset Adapter with M26 mount for the front strut of the front sight casting of M16/AR15 variants
- A21 Universal Housing Body [which forms part of the:]
- UxxT switch assembly. Note that xx is the length of the tape pressure switch cable in whole inches. "T" indicates the flag switch is for Constant-on/off. (BTW, if the flag switch is for disabling the tape pressure switch then it'd be UxxS)
I suppose it is closest to the model 676 which features the L36, A15 & M26, U05.
On that basis I would hazard that a model number could be 976T.
However, if you asked me what that was, I'd say:
L39, A15 & M26, A12, U05T
LE6920
USA
How many batteries do you have in there? And which lamp?
Like Al said, usually battery capacity was increased by extending the light body behind the A15 adapter, not by adding to the front.
It would seem with a L60 on the front that 2 batteries would be too long to fit and 1 would not make proper contact.
Size15's
Kettering, England
I have a doubt whether a single SF123A in that L60 will function in that configuration. I assumed that eg1977 would've mentioned if the light wasn't functioning...
eg1977
Texas
It came with 1 battery installed, but will fit 3 batteries (1 in front, 2 in back). It also came with a non-working Laser Products P60. I installed a P90 and 3 new CR123 batteries, it works fine.
LE6920
USA
Very interesting. The single battery up front does not rattle around at all?
koala
Melbourne, Australia
This isn't mine, a friend sent it in for a mod. A few dings here and there, good to see it has some heavy use. I'll take a better photo when it's done.
Status
