Sponsor Side Bendable Aluminum LED Channels For DIY Cove Lighting
ledbe
Vendor
The Side bendable Aluminum LED Channels are specifically designed for ceiling cove lighting. They can be easily installed along curved surfaces, ensuring seamless integration into various architectural elements on ceilings and coves to create elegant, curved lighting effects on the ceilings. The stock length is 1M, 2M, and 3M, and can be cut to any size to fulfill your needs. The Aluminum Channels are made of 6063-T5 extruded aluminum material and have a silver anodized surface treatment for anti-oxidation resistance and a longer lifespan. There are only semi-clear silicone diffusers available; they are made of high-quality silicone material, 50 meters or 100 meters per roll, and can be cut to any size. They will diffuse the light evenly, reduce glare, and create soft, dotless ambient lighting. The inner width is 15.5mm, and the max width of the Strip Lights is 15mm. Recommend installing Zig Zag S-shaped SMD LED Strip Lights as the light source.
Link: Bendable LED Strip Light Channels For Cove Lighting
