mobile1
UPDATE: The GatLight is born. We got the first REAL PROTOTYPE IN - so no rendered images this time. Go to this latest thread to see the images here
BRIGHTEST AND SMALLEST
How about a
[*]-R123 rechargeable powered
[*]-constant current regulated (Fatman)
[*]-Luxeon 5W (120 lumen)
[*]-NX01 optics (or similar sized other one)
[*]-1 inch diameter, less than 3 inches long
[*]-heat sinking area that is larger than a Mag2D head
[*]-dramatic design that allows to touch battery and reflector
[*]-WATER PROOF
[/list]
Think that's impossible. Here are some pictures (renderings) and the story, why it is possible (patent pending).
name me?
Next to an AA battery
Here is the story
The goal was to make an R123 battery light that can drive a 5W Lux. An R123 light is basically a rechargeble lithium ion 123 sized 3.7V -700mA cell that can deliver 5W. Problem with so much power in such a small package is heatsinking. So I tried to find new ways to increase heatsinking. (what follows by the way is patent pending)
I thought when I could use the inside of the light for heatsinking this would double heat sinking area. Problem with using the inside of a battery case for heatsinking is then the battery isn't water sealed anymore. So I though isn't a a battery in itself already water sealed.
An email to energizer whether a battery is waterproof provided the answer - here is there answer:
Thank you for contacting Energizer and also for your inquiry. At the end of production, the cells are actually washed in a mild Boric Acid solution. This removes any residual caustic that may have splashed onto the cans during production. Because the batteries are sealed, nothing would happen if a battery is accidentally dropped in water. Just wipe off the moisture and continue using the cell.
However, if the battery is immersed in water for an extended period of time, rusting may become a factor.
Thank you for contacting Energizer. Should you have any other questions feel free to contact us again.
Energizer Technical Support
So I asked myself why water sealing something that is already water proof. The same is true for the optics. Why water
sealing the entire optics when the optics are water proof (for example NX01).
So the goal was to design a light where optics and battery are not sealed. But where the emitter and driver plus positive battery contact are water sealed. Sealing is achieved by pressing optics and battery against an ORings = perfect sealing for emitter, electronics and battery plus contact.
The result is a design that has the heat sinking of a Mag2D head, but in a package of 1 inch diameter and a length of less than 3 inches. The design allows to touch battery and reflector (the one rod was purposely left out to make the design more dramatic). The light can be produced (3 milled out parts)
Regarding Driver, a slimed down version of George's fatman (taskled.com) would be used - the driver doesnt exist yet, but if there is enough interest in this light George would make one. At this moment no diming is possible for this setup even though the driver would allow it with a pot(haven't found one that could be made to fit)
However another feature that could be implemented (would increase the price though) would be an extendable battery case to accomodate for 2x 123 batteries without adding any new parts. If people think they would pay extra for this feature I could change the design to accomodate this feature. The price of this light will be at about USD 150 if we can get a large enough group interested in this light.
So for now, there are three questions for you to answer:
<ul type="square">
[*]1) Would you buy one for USD 150 (120 lumen, constant current regulated, water proof)
[*]2) Would you pay $40 more for an extendible battery case to accomodate 2x123 batteries. This would allow the extend the case without adding any new parts.
[*]3) Provide a name for this light.
[/list]
How about a
[*]-WATER PROOF
[/list]
name me?
Here is the story
<ul type="square">
[/list]
