Again, thanks. Your posts are extremely educational.
Sorry, but one more question.
And I think you addressed this somewhere else, but now I can't find it. Anyway, I suppose the fairly direct connection of the battery to the head imparts very little resistance to the circuit, depending on the quality/gauge of the connecting wires. I believe my DMM applies some internal resistance when measuring current draw, which I guess in theory would introduce a touch of voltage sag. Since the TK40 has constant output, that small voltage sag would cause it to draw a small amount of additional current. I'm guessing this would be small enough so as to have an insignificant effect on the measurements produced by this technique, particularly if you were measuring current draw while the light was powered on. I suppose it might be more significant to the measurement if you were trying to accurately measure "parasitic drain" while the light was powered off, since the current being drawn in that scenario is so low to begin with.
My question is: if you followed the alternative method of measuring current draw (i.e., the method that enables the switch, quoted below from your previous post), would the additional resistance imposed by the tailcap and body tube yield a different measurement of current draw?
To enable use of the switch, I must put the battery container into the body tube and also make a connection between the threads on the body tube and the treads on the head.
I'm guessing that, in theory, it would yield a slightly higher current for a constant power system like the TK40. But, I'm also guessing that the difference in current draw would not be significant unless you were trying to measure parasitic drain.
I'll try to resist from asking any additional questions so as to not wear too thin on your patience.
