simple idea so you dont drop your precious McGizmo lights
TITAN1833
Dark! Dank! Murky! England.
I use this when i using my ti s27-c..its not much but it has saved mine a few times..it is a o ring of suitable size..that fits finger,from the o ring nylon cord attaches to the light.. the snap lock you see is not needed..the length of cord you decide..much less bulk than lanyards. when not using its clipped back in my pocket..anyway just thought I would share.
Nice idea! I do something similar with a short piece of paracord looped through the clip. When not around my finger it acts as a fob. When in the woods and I don't want to accidentally drop it, I loop it around my ring finger and it sits in my hand perfectly. If I open my hand it hangs very securely.
Well I tried a lanyard as neck carry..but had to drop the light in a hurry.it was at breast bone level..well to say the least it hurt,this way I dont get hurt..and my light does not hit the floor.plus at the time I could have got strangled carrying it this way.
Good idea, TITAN1833, though I don't trust my lights to thin nylon cords. Eventually, they break. I may have to give it a try with some braided Spectra thread I have. Well, I've got to braid it first, but I've got the thread somewhere.
I've been using a simple wrist lanyard setup myself, using some Spectra cord I bought from Berkeley Point a couple of years ago and some cord hardware from CountyComm.
Using about 17" of cord (perfect for my wrist/hand), a cord terminator and one slip lock, I ended up with this:
I simply pull the loop up under the light's clip and I'm ready to go.
As you can see, when I'm holding a light, there isn't any loose cord hanging down. Since I don't go around equipment where there is a risk of getting caught, I think it's relatively safe. A quick disconnect could be used in place of the terminator, for those with concerns of catching the cord in something.
If anyone wants to try this, don't put the terminator on until you've got just the right length of cord to fit your wrist. One thing I really like about this setup is that you can simply press the button with your thumb, letting the cord provide the resistance, instead of having to use your other fingers to provide it. For this technique to work, the length of the cord has to be just right. At the same time, I've used the same lanyard with several lights, and it seems to work great with any of them.
So far, I've been quite happy with this setup - my light isn't going anywhere. At first, I thought the cord might become frayed from sliding it under clips all the time. I've been using it regularly for several months without any obvious fraying. Spectra's some seriously tough stuff. I suspect that either the cord lock or the clip would fail before the cord did.
I hope you don't mind me posting this in your thread...
If y 'all are looking for Spectra cord, which is really cool stuff by the way, try this...
I fly stunt kites for fun, and Spectra cord is my kite line of choice, so make a stop at your local kite/hobby shop if you're looking to buy it off the shelf and in person vs. having to order it online.
It's fairly thin stuff, but as mentioned above, a quick braid job gets it just about right for discreet carry.
Thanks,
Dutch
Actually you guys have given me an idea..I have some Brownell s4 bow string.which is light ,thin, but very stong ie a single strand has a braking strain of 165lb..i will experiment with this.12 strands will only be approx 2mm dia.
